Command 'coeff' (CAS Mode) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Command 'coeff' (CAS Mode) (/thread-21822.html) |
Command 'coeff' (CAS Mode) - hp-zl - 05-31-2024 07:05 PM There is a trigonometric series (screenshot): a:=(5*q+1)*sin(2*v)+(6*q^2+2)*sin(4*v) We want to find the coefficient of sin(2*v), so we do: coeff(a, sin(2*v),1) we get the correct result: 5*q+1. But when we type: coeff(a, sin(v*2),1) then we get zero. With 'sin(4*v)' similarly (see screenshot). The same results are given by both the physical calculator (with the latest firmware 2.1.14730) and the virtual calculator (HP_Prime_Virtual_Calculator-x86_64.AppImage, firmware 2.1.14288). What do you think about it? [attachment=13595] RE: Command 'coeff' (CAS Mode) - komame - 05-31-2024 07:51 PM This problem also occurs for much simpler cases. Assigning the expressions: 5*sin(2*x) and 5*sin(x*2) to the variables "a" and "b" results in "a" and "b" containing exactly the same expression: 5*sin(2*x). However, applying the coeff function to each of these variables yields different results => screenshot. [attachment=13597] RE: Command 'coeff' (CAS Mode) - parisse - 05-31-2024 08:24 PM coeff is meant to work on polynomials with respect to an identifier, not with respect to a subexpression. It will work only if the subexpression is written exactly the same way in an expression. If you run b:=sin(x*2) then the answer is displayed according to autosimplify mode, but b is not autosimplified. RE: Command 'coeff' (CAS Mode) - komame - 05-31-2024 08:54 PM (05-31-2024 08:24 PM)parisse Wrote: coeff is meant to work on polynomials with respect to an identifier, not with respect to a subexpression. It will work only if the subexpression is written exactly the same way in an expression. That's right. The syntax for the coeff in the help states that the second parameter should be [Var]. Moreover, setting the simplify parameter to 'None' in the CAS settings and repeating these operations explains everything. Thank you for the clarification. |
