HP49-50G: 2 FIX and the corresponding flag - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP49-50G: 2 FIX and the corresponding flag (/thread-21830.html) |
HP49-50G: 2 FIX and the corresponding flag - Gil - 06-04-2024 08:59 AM Suppose that the HP50G calculator was set previously on setting mode 2 FIX. To detect that setting in a program, ie that the 2 FIX mode is on, I could do << 7. 6 / —>STR "1.17" SAME IF THEN "FIX 2 Mode is set" ELSE "FIX 2 Mode is not set" END >> It's not very elegant. My question: What is the corresponding calculator FLAG combination/settings for the mode "2 FIX", "3 FIX", "4 FIX", etc. and STD ? Or what would be the most appropriate way to detect the issue? Thanks in advance for your help. Regards, Gil RE: HP49-50G: 2 FIX and the corresponding flag - Marco Polo - 06-04-2024 11:09 AM Mode and number of decimals are set in flags -49 and -50 (mode) and -45 through -48 (decimals) RE: HP49-50G: 2 FIX and the corresponding flag - Gil - 06-04-2024 11:22 AM Thanks. A very smart way this way of playing with binary representation of the number of digits. |
