SHARP PC-1500A with 12K Memory? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: SHARP PC-1500A with 12K Memory? (/thread-21964.html) |
SHARP PC-1500A with 12K Memory? - zixingcheche - 06-28-2024 05:38 AM Hello all I just got a PC-1500A with a CE-161.(SN:5A00571D) I check the memory by the command "NEW0" then "MEM" & ENTER, it returned "12090" on the screen. when installed the CE-161, it returned "28474" on the screen. Does anyone knows why this 1500A has 12K RAM? I checked the web, but I can not get any information on this. Thanks! BR, RE: SHARP PC-1500A with 12K Memory? - Csaba Tizedes - 06-28-2024 08:48 AM Start here, maybe this helps: SHARP PC-1500 + 16K onboard (assembled in Hungary) Cs. RE: SHARP PC-1500A with 12K Memory? - zixingcheche - 06-28-2024 10:15 AM Thanks!I will check it. |
