HP-45 Application Book (Not getting Correct Answer)) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-45 Application Book (Not getting Correct Answer)) (/thread-21966.html) |
HP-45 Application Book (Not getting Correct Answer)) - Namir - 06-28-2024 10:18 PM On Page 75 of the HP-45 Application Book, there are theory and instructions to solve for the roots of a cubic equation. I have tried both example. I get matching results with the first example, however I get different results with the second exmple. I also tried the calculation using MATLAB and they match the ones I got with the Free42. I get the same results which are: d = 1.7778 (determinant) x1 = 3.0000 + 0.5774i x2 = 1.0000 + 0.5774i x3 = 0.0000 - 1.1547i While the book gives the following results for the secon example (x^3-4*x^2+8*x-8=0): x1 = 2.00 x2 = 1 + 1.73i x3 = 1 - 1.73i (d = 1.78) I am applying the equations in the HP-45 Application Book still getting different answers. Here is the Free-42 code: Code: 01 LBL "CUBIC" The MATLAB command roots([1 -4 8 -8]) gives answers that match the HP-45 Application book. So, what am I doing wrong? You need to download the application book from Eric's website and go to page 74 and 75 to read the equations and the examples. Namir RE: HP-45 Application Book (Not getting Correct Answer)) - Albert Chan - 06-29-2024 12:54 AM Hi, Namir I have not read the book, nor your code, but this is easy to explain. ³√(-8) = -2, but (-8)^(1/3) = -2*ω, where ω = cis(2*pi/3) = (-1 + i√3) / 2 Because of this ambiguity, below is a *bad* cubic formula. x might not be a root al all! One term might require ω factor correction. Instead of doing 2 cube roots, do only 1, and derive the other, guaranteed correct one. Bonus: we can get the one with least cancellation errors, and have both accurate terms. x^3 - 4*x^2 + 8*x - 8 = 0 // let x = y + 4/3 y^3 + 8/3*y - 56/27 = 0 // c = 8/3, d = 56/27, to match above formula --> (y - (α + β)) * (y - (α*ω + β/ω)) * (y - (α/ω + β*ω)) = 0 α = ³√(d/2 + √((d/2)^2 + (c/3)^3)) = ³√(28/27 + 4/3) = ³√(64/27) = 4/3 β = (-c/3) / α = (-8/9) / (4/3) = -2/3 β is correctly paired with α --> all generated roots are correct. x = 4/3 + y x1 = 4/3 + (4/3) + (-2/3) = 2 x2 = 4/3 + (4/3)*ω + (-2/3)/ω = 1 + i√3 x3 = 4/3 + (4/3)/ω + (-2/3)*ω = -1/3 − i√3 Had we use cube root for β, we may get (28/27 - 4/3)^(1/3) = -2/3/ω XCas> ω := exp(i*2*pi/3) XCas> float(normal([[1,1],[ω,1/ω],[1/ω,ω]] * [4/3, -2/3/ω] .+ 4/3)) [3.0+0.57735026919*i, 1.0+0.57735026919*i, -1.15470053838*i] RE: HP-45 Application Book (Not getting Correct Answer) - Thomas Klemm - 06-29-2024 01:41 AM (06-28-2024 10:18 PM)Namir Wrote: While calculating B in line 56, the x-value is negative. Calculating the cubic root returns the principal value. This is a complex number. What you want to calculate instead is the negative of the cubic root of the negative value. This is handled in the HP-45 Application Book. RE: HP-45 Application Book (Not getting Correct Answer)) - Namir - 06-29-2024 02:14 AM Thanks Albert and Thomas! Namir RE: HP-45 Application Book (Not getting Correct Answer)) - Namir - 06-30-2024 08:49 PM Good news! I was able to adapt the HP-45 listing for the HP-41C and posted the adaptation in the HP41C Software Library section. The solution uses flags and labels to correctly direct the flow of calculations. Namir |
