Sharp PC-E500 to PC link issues - Printable Version
+--- Thread: Sharp PC-E500 to PC link issues (/thread-22058.html)
Sharp PC-E500 to PC link issues - fy789 - 07-21-2024 02:25 PM
Hi all,
I bought the RS232C-to-USB cable from tmfg.jp
to facilitate file transfer from PC to Sharp PC-E500.
I follow the instruction on their website to transfer
a file from PC to the E500:
1. First, I connect the cable to the PC and the E500
(Drivers on the PC side are preloaded)
2. Then I set up the E500 port by using
OPEN "9600,N,8,1,A,L,&H1A,N,S":CLOSE
3. Then I put the E500 into RECEIVE mode:
LOAD
However, after the "LOAD" command, the E500
always return "I/O error". Is this ok?
The E500 is supposed to sit there waiting for the
bitstream to come in.
I have read thru quite a few discussions here as well
as a few other places, and there are a lot of info.
(i) logic inversion of 4 flow control signals
(the FTDI chip manufacturer has a configure tool to do this,
but it has not been updated to run on Win10 or Win11).
Is this necessary?
(ii) I assume the FTDI chip will do the voltage level conversion.
BTW, I appreciate if anybody successfully doing this before
can post a cheatsheet to walk thru the steps and the tools
used (TeraTerm, HTerm, PC-E500-Notepad....etc) ?
Thanks!
RE: Sharp PC-E500 to PC link issues - toml_12953 - 07-21-2024 08:52 PM
(07-21-2024 02:25 PM)fy789 Wrote:  Hi all,
Is the CLOSE really necessary?
Have you tried it without the CLOSE?
RE: Sharp PC-E500 to PC link issues - Helix - 07-21-2024 09:25 PM
I don’t have this cable, but a DIY interface made with a genuine FTDI chip, that works identically on Windows 7 and 11.
On the SHARP, the parameters I use are:
OPEN "9600, N, 8, 1, A, L, &1A, N, N": CLOSE
This has to be done only once, as the parameters are registered afterward.
I use Hterm, with the following settings:
Port: must be checked in the Windows Device Manager
Baud: 9600
Data: 8
Stop: 1
Parity: none
CTS flow control: ON
ASCII: ON
RTS: ON (below the "Recieved Data" window)
Then to load a program:
Sharp: LOAD "COM:"
Hterm: Connect - Send File… Start
To save a program:
Sharp: SAVE "COM:"
Hterm: Connect - Save Output
To exchange ASCII files, the command on the Sharp is:
COPY "COM:" TO "E:filename" or COPY "E:filename" TO "COM:"
This is MY cheat sheet.
RE: Sharp PC-E500 to PC link issues - fy789 - 07-22-2024 02:46 AM
Hi Jean-Charles,
Thanks for the cheatsheet!
I think there is a typo on the OPEN statement: "&1A" should be "&H1A" for
hexadecimal.
May I know if you used the VCP or D2xxx driver to enable the port?
BTW, I follow your instruction, but I still get the same "I/O error" after "LOAD COM:"
I tried it on another similar machine, PC-E650, and I got the same error.
The cable may be the issue.
Could you show me how to construct the cable?
Where did you purchase the 15-pin header connector ?
Any hint?
Was the I/O port toasted?
Thanks!
HTerm and Device Driver screen captures:
https://ibb.co/6R98gNn
https://ibb.co/D7Khh92
(07-21-2024 09:25 PM)Helix Wrote:  I don’t have this cable, but a DIY interface made with a genuine FTDI chip, that works identically on Windows 7 and 11.
Baud: 9600
Data: 8
Stop: 1
Parity: none
ASCII: ON
Sharp: LOAD "COM:"
To save a program:
Sharp: SAVE "COM:"
RE: Sharp PC-E500 to PC link issues - fy789 - 07-22-2024 02:50 AM
The LOAD command will automatically open the port when it is invoked;
this is documented in the PC-E500 operation manual.
RE: Sharp PC-E500 to PC link issues - Helix - 07-22-2024 11:32 PM
(07-22-2024 02:46 AM)fy789 Wrote:  I think there is a typo on the OPEN statement: "&1A" should be "&H1A" for
hexadecimal.
Hexadecimal numbers are valid without the H letter. This is not mentioned in the manual.
Quote:May I know if you used the VCP or D2xxx driver to enable the port?
With Windows 11, I had nothing to install!
For Windows 7, I don’t remember the driver, but I’ve found in my archives two files named CP210xVCPInstaller_x86.exe and CP210xVCPInstaller_x86.exe, so I suppose it’s VCP.
Quote:BTW, I follow your instruction, but I still get the same "I/O error" after "LOAD COM:"
I don’t know this I/O error.
You will find a picture of my cable here, some explanations here, and a more complete PDF document.
The 1.27 mm pitch connectors are not easy to find, and certainly not easy to solder, so I managed to make my own connector with thin cables and some glue.
Another difficulty is to find a genuine FTDI chip, because there are many fake chips that work correctly, but whose signals can’t be inverted.
In your Hterm settings, try to enable the RTS box.
example
Also, the port is visible in the "Port (COM & LPT)" line, not the USB line.
example
RE: Sharp PC-E500 to PC link issues - fy789 - 07-24-2024 02:54 PM
I contacted the staff at the manufacturer, tmfg.jp, and after multiple rounds of correspondence, apparently they forgot to program the logic
inversion of the 4 flow-control signals. They send me the instructions to do the flash programming and it works afterwards.
Now, I can use "LOAD" without any issue afterwards for transferring a BASIC games into the E500S successfully. (ASCII file)
Thanks to all who tried to help!
