(41CV) Calculator Programs for Pipe Stress Engineering - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP-41C Software Library (/forum-11.html) +--- Thread: (41CV) Calculator Programs for Pipe Stress Engineering (/thread-22143.html) |
(41CV) Calculator Programs for Pipe Stress Engineering - SlideRule - 08-08-2024 11:29 AM An excerpt from Calculator Programs for Pipe Stress Engineering, Wiley © 1986, 403 pages Table of Contents Part I PIPING FLEXIBILITY Chapter 1 Elastic Center pipe stress analysis: TI-59-1 HP-41CV-1 Chapter 2. The need for thrust blocks in buried Thermoelastic Resin pipe: TI-59-2 HP-41CV-2 Chapter 3. First natural frequency for three distinct piping layouts: TI-59-3 HP-41CV-3 Chapter 4. Flexibility factors, virtual lengths and intensification factors: TI-59-4 HP-41CV-4 Part II PIPE STRESS Chapter5. Flanged connection bolt tensioning: TI-59-5 HP-41CV-5 Chapter6. Fillet weld sizing: HP-41CV-6 (only) Chapter. 7 Shell stresses from externally applied loads on welded attachments: TI-59-7 HP-41CV-7 Chapter 8 Allowable pipeway spans for steel pipe: TI-59-8 HP-41CV-8 Chapter 9. Support ring stresses: TI-59-9 HP-41CV-9 Part III INTERNAL PRESSURE Chapter 10. Pressure reinforcing pads per ASME/ANSI B31.3: TI-59-10 HP-41CV-10 Chapter 11. TI-59-11.1 Maximum allowable working pressure TI-59-11.2 Minimum pipe wall thickness based on internal pressure TI-59-11.3 Pipe- wall thickness class array for seamless and plate-fabricated pipe HP-41CV-11 Pipe wall thickness by class and single OD, and maximum allowable working pressure Part IV SPECIAL APPLICATIONS Chapter 12 Turbo-machinery loading analysis per NEMA SM-23 and API-617: TI-59-12 HP-41CV-12 Chapter 13. Buried concrete thrust block sizing in cohesionless soils: TI-59-13 HP-41CV-13 Bibliography BEST! SlideRule |
