(25) Frequency-Response Calculations w ⁄ - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: (25) Frequency-Response Calculations w ⁄ (/thread-22152.html) |
(25) Frequency-Response Calculations w ⁄ - SlideRule - 08-09-2024 04:30 PM An excerpt from Frequency-Response Calculations with a programmable calculator, E. E. Mitchell, U.S. Naval Academy, 1977/07, 4 pages. ABSTRACT This paper describes an algorithm with which the user can compute frequency responses on a small pro- grammable calculator. Inexpensive calculators like the Hewlett-Packard 25 allow such calculations for a system containing as many as four poles and zeros. The user must enter the proper sequence for a pole or zero, but the process is simple; the user does not have to depend on (and wait for) a large computer. The paper presents the solution of a typical problem. … INTRODUCTION The frequency response of a linear system is the steady-state response of the system to a sinusoidal input … … Frequency-response techniques may be used to experi- mentally determine the transfer function of an un- known system … … Numerical techniques exist that are simple, easy to program, don’t require a large computer, and will quickly calculate the frequency response of large (tenth-order) systems … … For frequency response calculations, the use of a programmable calculator can provide higher accuracy than straight-line approximations … … Because of the limitations on program steps and memory storage, programs for small calculators tend to be very specific … … This paper describes a program written for a program- mable pocket calculator that computes the frequency response of linear systems … … DESCRIPTION OF THE CALCULATOR The following operations are those utilized by the inexpensive HP25 (Hewlett Packard) programmable pocket calculator. These functions are common in the HP scientific calculator series and should be understandable to the users of other programmable calculators. … … … CONCLUSIONS The sequence of steps will work on any calculator, even the nonprogrammable types, such as the HP35 and HP45. The maximum problem size depends on the maxi- mum number of storage locations and program steps. The example just shown had a total of four poles and zeros. This is the maximum size for a problem on the HP25, the limitation being the availability of only eight memory locations. The program is surprisingly easy to use; … … BEST! SlideRule |
