Hp Algorithm to create random numbers - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Hp Algorithm to create random numbers (/thread-22161.html) |
Hp Algorithm to create random numbers - Gil - 08-12-2024 11:42 AM When pressing on HP50G NumberX RDZ... RAND, we get always the same random number, whatever... is. That's OK and that's what we want. Question. Does somebody know what is the algorithm (the internal special function) used by HP calculators to generate pseudo random numbers ? Thanks for your answer. RE: Hp Algorithm to create random numbers - Thomas Klemm - 08-12-2024 07:26 PM (08-12-2024 11:42 AM)Gil Wrote: Does somebody know what is the algorithm (the internal special function) used by HP calculators to generate pseudo random numbers ?
RE: Hp Algorithm to create random numbers - Gil - 08-13-2024 12:58 AM Thanks for the reference, Thomas. Regards, Gil RE: Hp Algorithm to create random numbers - Gil - 08-13-2024 10:24 PM With the first reference I press, on my HP50G, the command RAND and get R(n) =.821118792263 (1) and build R(n)_int =821118792263 (an integer) (2) Then I multiply 2851130928467 (3) by R(n) and get 2.34111718457E12 (4) Then I multiply also 2851130928467 (3) by R(n)_int and get 2341117184566508886050821 (5) Pressing a second time RAND gives R(n+1)=.994325264552 (6) I thought, with the explanations of the first reference, that the digits of (6), R(n+1), should be found somewhere in (5) or (6). But it's clearly not the case. Could somebody explain my error or give a detailed example? Thanks in advance. Regards, Gil RE: Hp Algorithm to create random numbers - Albert Chan - 08-13-2024 11:38 PM Hi, Gil It is a difference of random state vs random output Quote:R(n) =.821118792263 (1) Output is 12 digits, but random state is really 15 (red numbers cracked by brute force) 821118792263521 * 2851130928467 % 10^15 = 994325264552307 We drop next state last 3 digits for next random output. Quote:Pressing a second time RAND gives RE: Hp Algorithm to create random numbers - DavidM - 08-14-2024 02:38 AM As Albert also indicated, the internal seed is actually 15 decimal digits. Here's another series of examples that might help to show what's happening. First, I'll set the seed to a nice number with RDZ so that this can be easily replicated: 1E-13 RDZ The internal seed now has a value of 000000000000001. Executing RAND at this stage causes the following: new_seed = (000000000000001 x 2851130928467) MOD 10^15 = 002851130928467 RAND result is normalized to 2.85113092846E-3 * Next RAND: new_seed = (002851130928467 x 2851130928467) MOD 10^15 = 261097470970089 RAND result is normalized to 0.26109747097 Next RAND: new_seed = (261097470970089 x 2851130928467) MOD 10^15 = 335429755623563 RAND result is normalized to 0.335429755623 Next RAND: new_seed = (335429755623563 x 2851130928467) MOD 10^15 = 468090732667921 RAND result is normalized to 0.468090732667 * The normalization step appears to shift out any leading zeros before truncating the last three digits. RE: Hp Algorithm to create random numbers - Gil - 08-15-2024 05:16 PM Thanks to Albert for his cracking effort and to David for his detailed examples and explanations. Gil RE: Hp Algorithm to create random numbers - Gil - 08-19-2024 10:23 PM And what is the algorithm/function to get the first RANDom number when entering x RDZ RAND (x a real number)? Thanks for partaking this information. Regards, Gil RE: Hp Algorithm to create random numbers - DavidM - 08-21-2024 05:43 PM (08-19-2024 10:23 PM)Gil Wrote: And what is the algorithm/function to get the first RANDom number when entering x RDZ RAND (x a real number)? RAND is no different in this scenario than previously described, so what you're really asking is "how does RDZ compute a seed?", which turns out to be difficult to explain without some Saturn assembly knowledge. The Saturn code for RDZ is concise and efficient, but it doesn't map well to higher-level mathematical translation because it is heavily dependent on the internal representation of reals and "bit-twiddling" steps that are much easier to do in Saturn code than they are with traditional numeric calculations. That said, I've attempted to create a User RPL version of RDZ that returns an exact integer seed for the given basis, leaving it on the stack instead of storing it internally. It treats an input of 0 in the same way that RDZ does, ie. using the system clock for the seed basis. This code requires a 49g/49g+/50g due to its use of exact integers. The use of reals and integers is important here, so the program should be transferred while the destination calculator is in exact mode. Code: RDZU Note that the resulting seed should be interpreted as having leading 0s if its length is less than 15 digits. So a result of 999001 should be interpreted as 000000000999001 when stored internally. Some examples 1E-13 RDZU => 1 12345. RDZU => 123450000000051 9.87654321098E295 RDZU => 987654321098961 0.000000000999 RDZU => 999001 Full RAND check 12345 RDZU => 123450000000051 2851130928467 * => 351972113119396557677351817 10 15 ^ MOD => 396557677351817 ...so RAND should be 0.396557677351 12345 RDZ RAND => 0.396557677351 9.99E-10 RDZU => 999001 2851130928467 * => 2848282648669461467 10 15 ^ MOD => 282648669461467 ...so RAND should be 0.282648669461 9.99E-10 RDZ RAND => 0.282648669461 RE: Hp Algorithm to create random numbers - Gil - 08-22-2024 10:11 PM A great thank to you, David. I will study your programs later with calm. Regards, Gil RE: Hp Algorithm to create random numbers - Albert Chan - 08-23-2024 01:42 PM (08-21-2024 05:43 PM)DavidM Wrote: Some examples RDZU seems to use 12 digits mantissa + 2 digits exponents (by MOD 100) + final 1 to make 15 digits Code: .000000 000000 1 E000 --> 000000 000000 001 Mantissa first 12 digits is zero only when seed is small. I would expect smaller seed (< 1E-13) would adjust exponent field. (to get state ??1) This was my guess. 1E-13 --> 001 1E-14 --> 991 1E-15 --> 981 1E-16 --> 971 ... But when I try RDZ, above 4 cases all give random state 001 Only when seed get smaller, does this state pattern activated, why the gap? 1E-13 --> 001 1E-14 --> 001 1E-15 --> 001 1E-16 --> 001 1E-17 --> 991 1E-18 --> 981 1E-19 --> 971 ... RE: Hp Algorithm to create random numbers - DavidM - 08-24-2024 12:05 AM (08-23-2024 01:42 PM)Albert Chan Wrote: But when I try RDZ, above 4 cases all give random state 001 There's more to RDX's algorithm than your table implies. RDX separates the mantissa and exponent fields of the real number given as input, and then treats the mantissa as a 15-digit integer while combining the two into a seed. The exponent stays as a 3-digit number, but it may not be what you expect due to the special way negative exponents for reals are encoded in the Saturn architecture. Specifically, negative exponents are encoded as 1000-ABS(exponent), but RDX simply treats that result as a 3-digit positive integer. The denormalization section of the code performs right-shifts on the mantissa based on the exponent value. Note that there are 3 independent exit conditions in RDX's denormalization loop: - the mantissa becomes 0 as a result of repeated right-shifts, OR - (2*exponent) <= 998 (ie. a carry does NOT occur as a result of 2*exponent), OR - (2*exponent) MOD 1000 is 0 So here's the critical values for some specific inputs that will hopefully show what's happening. Input 1E-12 Initial mantissa: 100000000000000 Initial exponent: 988 Mantissa after denormalization: 000000000001000 Exponent after denormalization: 000 Exponent after shift-left: 000 Exponent after increment: 001 Seed: 000000000001001 Input 1E-13 Initial mantissa: 100000000000000 Initial exponent: 987 Mantissa after denormalization: 000000000000100 Exponent after denormalization: 000 Exponent after shift-left: 000 Exponent after increment: 001 Seed: 000000000000001 Input 1E-14 Initial mantissa: 100000000000000 Initial exponent: 986 Mantissa after denormalization: 000000000000010 Exponent after denormalization: 000 Exponent after shift-left: 000 Exponent after increment: 001 Seed: 000000000000001 Input 1E-15 Initial mantissa: 100000000000000 Initial exponent: 985 Mantissa after denormalization: 000000000000001 Exponent after denormalization: 000 Exponent after shift-left: 000 Exponent after increment: 001 Seed: 000000000000001 Input 1E-16 Initial mantissa: 100000000000000 Initial exponent: 984 Mantissa after denormalization: 000000000000000 Exponent after denormalization: 000 Exponent after shift-left: 000 Exponent after increment: 001 Seed: 000000000000001 Input 1E-17 Initial mantissa: 100000000000000 Initial exponent: 983 Mantissa after denormalization: 000000000000000 Exponent after denormalization: 999 Exponent after shift-left: 990 Exponent after increment: 991 Seed: 000000000000991 Input 123456.123456 Initial mantissa: 123456123456000 Initial exponent: 005 Mantissa after denormalization: 123456123456000 Exponent after denormalization: 006 Exponent after shift-left: 060 Exponent after increment: 061 Seed: 123456123456061 Note how the last 3 digits of the mantissa get obliterated by the altered exponent in each example. RE: Hp Algorithm to create random numbers - Albert Chan - 08-24-2024 12:34 PM (08-24-2024 12:05 AM)DavidM Wrote: RDX separates the mantissa and exponent fields of the real number given as input, Thanks, 15 digits mantissa make sense. However, 16 digits mantissa is simpler to understand RDZ logic. Code: 1E-12 = .0000 0000 0001 0000 E000 --> 0000 0000 0001 00 1 RE: Hp Algorithm to create random numbers - Gil - 08-25-2024 10:52 AM Despite all your detailed explanations, David, would it be possible to work out a detailed example, again step by step, to get the RAND om number .510262440213 after entering 2.567 RDZ on the HP50G? And perhaps also, if I may ask, for RANDom number .163041130928 after entering 0.002567 RDZ? Thanks in advance for your painstaking, David. Regards, Gil RE: Hp Algorithm to create random numbers - DavidM - 08-25-2024 12:02 PM (08-25-2024 10:52 AM)Gil Wrote: Despite all your detailed explanations, David, would it be possible to work out a detailed example, again step by step, to get the RAND om number .510262440213 In your first example, entering 2.567 RDZ produces an internal seed value of 256700000000011. When executing RAND immediately following that, we have the following: new_seed_value = (256700000000011 * 2851130928467) MOD 10^15 = 510262440213137 The normalization process for that integer yields 0.510262440213 for the final RAND result. In your second example, it appears that you may have inadvertently left out the "6" when executing "0.002567 RDZ": 0.00257 RDZ RAND => 0.163041130928 0.002567 RDZ RAND => 0.377640130928 The only reason I figured that out was that I did the same exact thing when testing this after reading your post -- it had me confused for a minute or so until I subsequently typed it in correctly on a second try. So here's the same process for that input. Entering 0.002567 RDZ produces an internal seed value of 2567000000001. When executing RAND immediately following that, we have the following: new_seed_value = (2567000000001 * 2851130928467) MOD 10^15 = 377640130928467 The normalization process for that integer yields 0.377640130928 for the final RAND result. Does this help? RE: Hp Algorithm to create random numbers - Albert Chan - 08-25-2024 02:50 PM (08-25-2024 12:02 PM)DavidM Wrote: In your second example, it appears that you may have inadvertently left out the "6" when executing "0.002567 RDZ": Assuming 1E-16 ≤ seed < 1, we know original state must end in 001 --> state * 2851130928467 ≡ 163041130928467 (mod 10^15) 1/2851130928467 ≡ -46007610876197 ≡ 953992389123803 (mod 10^15) (*) --> state ≡ 163041130928467 * 953992389123803 ≡ 002570000000001 (mod 10^15) --> seed = 0.00257 (*) Calculations based on Euclidean GCD calculations, then scale-up for mod inverse, see here 1E15 --> -floor(446607260/9707247377 * 1E15) = -46007610876197 2851130928467 + 2104175036550 - 746955891917 + 610263252716 - 136692639201 + 63492695912 - 9707247377 --> +floor(13843/300885 * 9707247377) = 446607260, 9.71E9*6.35E10 ≈ 6.2E20 5249211650 - 4458035727 + 791175923 - 502156112 + 289019811 - 213136301 + 75883510 - 61369281 + 14514229 - 3312365 + 1264769 - 782827 + 481942 - 300885 --> -floor(-19/413 * 300885) = 13843, 3.01E5*4.82E5 ≈ 1.4E10 181057 + 119828 - 61229 + 58599 - 2630 + 739 - 413 --> -floor(1/21 * 413) = -19, 413*739 = 305207 326 + 87 - 65 + 22 - 21 --> 1/1 ≡ 1 (mod 21), 21*22 = 462 1 = gcd RE: Hp Algorithm to create random numbers - Gil - 08-25-2024 05:51 PM Thanks for your answer, David. The seed is OK and RAND calculation also. But could you detail the internal_seed with 2.567. —> 257....001? Thanks again in advance, David. Gil RE: Hp Algorithm to create random numbers - DavidM - 08-25-2024 07:47 PM (08-25-2024 05:51 PM)Gil Wrote: But could you detail the internal_seed with 2.567. The computation of RAND is a straightforward chain of mathematical operations that's easy to describe. The conversion of a real number to a random seed (RDZ) isn't as easy to explain, mainly due to the variability of what happens during the denormalization process. Your best bet would be to step through the code with DBUG so you could watch the stack contents change with various inputs. At a high level, RDZ/RDZU works as follows (using 2.567 as the example here): 1) The input is altered to conform to standard (non-zero positive real): 2.567E0 2) That value is separated into two intermediate pieces. mantissa (256700000000000) and exponent (0) 3) Denormalization occurs (the actual steps here vary with the input). For this example, the end result is: Code: 2: 256700000000000 (mantissa) 4) exponent is then shifted left 1 digit: Code: 2: 256700000000000 (mantissa) 5) exponent is incremented by 1: Code: 2: 256700000000000 (mantissa) 6) Finally, the last three digits of mantissa are replaced by the full 3-digit form of exponent: Code: 1: 256700000000011 (final seed value) RE: Hp Algorithm to create random numbers - Albert Chan - 08-25-2024 10:11 PM (08-25-2024 02:50 PM)Albert Chan Wrote: Assuming 1E-16 ≤ seed < 1, we know original state must end in 001 It may be better to reduce modulus from huge 10^15 down to size, to simplify mod inverse calculations. Let state = 1000 * x + 001, where x is 12 digits integer x * 2851130928467 ≡ (163041130928467 - 2851130928467) / 1000 ≡ 16019 * 10^7 (mod 10^12) Last 7 digits of x must be 0. Let x = 10^7 * y, where y is 5 digits integer y * 28467 ≡ 16019 (mod 10^5) Again, Euclidean GCD, follow by scaling up to get modulo inverse. 10^5 --> +floor(3475/14599 * 10^5) = 23803 28467 - 14599 --> +floor(5/21 * 14599) = 3475, 14599*28467 > 10^5 13868 - 731 + 710 - 21 --> +floor(1/4 * 21) = 5, 21*710 = 14910 17 - 4 --> 1/1 = 1 (mod 4), 4*17 = 68 1 = gcd y ≡ 16019 / 28467 ≡ 16019 * 23803 ≡ 00257 (mod 10^5) --> state = 00257 0000000 001 --> seed = 0.00257 Another way, by checking last digits y * 28467 ≡ 16019 (mod 10^5) // multiply both side by 3, to make 7 to 1 y * 85401 ≡ 48057 (mod 10^5) // y must end in 57 Let y = 100*z + 57 z * 85401 ≡ (48057 - 57*85401) / 100 ≡ -48198 (mod 10^3) z * 401 ≡ 802 (mod 10^3) // z must end in 02 z ≡ 802/401 ≡ 002 (mod 10^3) --> y ≡ 002 57 (mod 10^5) RE: Hp Algorithm to create random numbers - Albert Chan - 08-26-2024 11:21 AM (08-25-2024 02:50 PM)Albert Chan Wrote: state * 2851130928467 ≡ 163041130928467 (mod 10^15) Faster way to solve, scale to reduce multiplier to 1, 2nd column is state. Cas> m := 10^15 Cas> [2851130928467, 163041130928467] * 3; /* force multiplier last digit = 1 */ [8553392785401,489123392785401] Cas> (Ans*(2-Ans[1])) MOD m [667229546840001,469799546840001] [246014400000001,248584400000001] [1,2570000000001] --> state = 002570000000001 This trick work for other modulus too. Also, MOD can be signed mod Example: solve 7x ≡ 9 (mod 3^5) Base 3, last digit 7%3 = 1, we keep scaling to zeroed out other digits. Cas> [7, 9] %% 3^5 Cas> Ans*(2-Ans[1]) [-35 %% 243,-45 %% 243] [-80 %% 243,36 %% 243] [1 %% 243,36 %% 243] --> x ≡ 9/7 ≡ 36 (mod 3^5) |
