HP-15C CE speed improvement over OG 15C - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP-15C CE speed improvement over OG 15C (/thread-22210.html) |
HP-15C CE speed improvement over OG 15C - RPNerd - 08-22-2024 03:25 PM It's obvious that the 15C CE was going to be a lot faster than the original 15C but I wanted to get an idea of how much faster, so I decided to let them both loose on a problem that should involve quite a bit of number crunching. I settled on the problem entitled "Using the Solver with Simultaneous Equations" om pp168-169 of "Programming Examples and Techniques" for the HP-42S (see https://literature.hpcalc.org/items/934). My OG HP-15C chewed through it in approx. 1m15s, which I thought was pretty good for a calculator that was never particularly fast in the first place repeatedly solving a 4x4 system of linear equations until the correct value for one of the coefficients is found. The HP-15C CE tore through it in a fraction of a second. Case closed. RE: HP-15C CE speed improvement over OG 15C - AnnoyedOne - 08-22-2024 03:31 PM (08-22-2024 03:25 PM)RPNerd Wrote: The HP-15C CE tore through it in a fraction of a second. Yeah. Modern 32-bit (ARM) based models are much faster even when emulating original NUT code. My 2022 HP-12C+ does the same thing :-) RE: HP-15C CE speed improvement over OG 15C - RPNerd - 08-22-2024 03:42 PM (08-22-2024 03:31 PM)AnnoyedOne Wrote: Yeah. Modern 32-bit (ARM) based models are much faster even when emulating original NUT code. Even my SwissMicros DM15L (also ARM 32-bit emulating NUT code) running at 48 MHz needed about 4 seconds to get the answer (about 18s @ 12 MHz). RE: HP-15C CE speed improvement over OG 15C - AnnoyedOne - 08-22-2024 03:51 PM (08-22-2024 03:42 PM)RPNerd Wrote: Even my SwissMicros DM15L... I considered buying one of those but heard about the HP-15C CE and got one of those instead. The DM15L uses a NXP LPC1115 with has a ARM Cortex M0 core. The HP-15C CE has a Cortex M4. About 4x faster it seems. I was actually looking hard at using a LPC111x in a new design in 2009. In the end I stuck with the Cortex M3 chip I'd already used. A1 |
