fourier series coefficients. - Printable Version
+--- Thread: fourier series coefficients. (/thread-22580.html)
fourier series coefficients. - truble@mill - 10-26-2024 04:23 AM
I'm using fourier_an and fourier_bn. Results are unreliable. Result is often 'undef'. See attached.
an_setup_1 shows setup for cosine coefficients.
an_setup_2 shows result. Undef.
an_setup_help_page shows Prime help suggestions.
fourier_bn working example shows typical results expected.
BTW, fourier_an results should be +/- 8/n*pi for n odd and 0 for n even.
Can anyone explain my error? Thank you.
RE: fourier series coefficients. - parisse - 10-26-2024 07:41 PM
The CAS can only handle integration of piecewise with one linear inequation.
Workaround: rewrite your expression under this constraint. For example
fourier_an(-2+4*piecewise(x>-pi/2,1,0)*piecewise(x<pi/2,1,0),n)
RE: fourier series coefficients. - truble@mill - 10-27-2024 06:25 AM
Thank you for your reply. It certainly works but I do not follow your workaround.
Could you add some explanation? For example, why you decided x>-pi/2 and what the other parameters are inside the piecewise function.
Thanking you.
RE: fourier series coefficients. - parisse - 10-27-2024 07:08 AM
Much better workaround:
fourier_an(piecewise(x<-pi/2,-2,x<pi/2,2,-2),n)
RE: fourier series coefficients. - truble@mill - 10-28-2024 05:14 AM
Yes. Agreed. I'll be able to adapt that code. Thanking you again.
