Old programs do not run - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Old programs do not run (/thread-22622.html) |
Old programs do not run - BuSchu - 11-01-2024 01:17 PM After a long time, I wanted to start my few programs again. But none of them can still run. When I look at the program text and select "check", I only get the error message "Error: Syntaxerror". And that with every program. Then when I press ESC twice, I always get the message that there is a syntax error on line 6. Here is my simplest test program: EXPORT Testinput() BEGIN LOCAL name; INPUT ({{name, [-1]}}, "Name", "Please type in a name"); PRINT("Hello " + name); END; Why am I getting a syntax error with this tiny program now? Thank you for your help! RE: Old programs do not run - Arno K - 11-01-2024 04:17 PM Hello, I opened a new program on my emulator, emptied it and copied your text in. Check: No errors, program runs as expected. Software is: 2.1.14730 Arno RE: Old programs do not run - BuSchu - 11-01-2024 06:46 PM On both Primes the same, both with actual firmware: The program does not run. RE: Old programs do not run - Dougggg - 11-01-2024 08:12 PM do you have the latest firmware 2.2 9/1/24 on my G2 with the latest firmware I copied and pasted the program and it seems to works ok no error RE: Old programs do not run - BuSchu - 11-01-2024 08:30 PM (11-01-2024 08:12 PM)Dougggg Wrote: do you have the latest firmware 2.2 9/1/24 As I wrote: actual firmware. And actual means latest, of course. All my old programs report a syntax error in line 6. Could it be a configuration problem? Now I saw: The following short program shows a syntax error in line 1: EXPORT Mopmt (L, R, M) BEGIN LOCAL K := R / 1200; K := L * K / (1 - (1 + K)^ -M); RETURN "Payment = " + K; END; RE: Old programs do not run - BuSchu - 11-01-2024 08:57 PM Now I cleared memory and keyed in the program mompt and it works. RE: Old programs do not run - BuSchu - 11-01-2024 08:59 PM After restoring the backup before the memory reset the error is there again. RE: Old programs do not run - Raymond Del Tondo - 11-01-2024 09:34 PM Did you consider inserting something like this: Code: #pragma mode( separator(.,;) integer(h32) ) The #pragma line ensures that your preferred settings are used when compiling the text into a program. More about the #pragma directive can be found here in the hpmuseum forum. RE: Old programs do not run - BuSchu - 11-01-2024 10:12 PM (11-01-2024 09:34 PM)Raymond Del Tondo Wrote: Did you consider inserting something like this: I think, that's it. I configured , as the separator as common in Germany. Thanks! RE: Old programs do not run - RPNerd - 11-02-2024 08:25 AM (11-01-2024 08:30 PM)BuSchu Wrote: As I wrote: actual firmware. To remove some confusion here, I think BuSchu means "up-to-date" firmware, which is "actuel" in French. One of the many false friends between the two languages. RE: Old programs do not run - BuSchu - 11-02-2024 09:27 AM (11-02-2024 08:25 AM)RPNerd Wrote:(11-01-2024 08:30 PM)BuSchu Wrote: As I wrote: actual firmware. Thanks. I didn't know that until now! |
