Y=LOGB(2,X) problem - Printable Version
+--- Thread: Y=LOGB(2,X) problem (/thread-22658.html)
Y=LOGB(2,X) problem - compsystems - 11-08-2024 04:27 PM
Hello
There is a problem with the grapher
Y=LOGB(2,X)
https://www.wolframalpha.com/input?i=logbase2%28x%29
RE: Y=LOGB(2,X) problem - Patocuy - 11-08-2024 06:56 PM
Hi, the HP Prime graphics are ok. The documentation of the function states that the first parameter is the value and the second parameter is the base.
Y=LOGB(X,2) is the same as WA Log(2,x):
https://www.wolframalpha.com/input?i2d=true&i=log%5C%2840%292%5C%2844%29x%5C%2841%29&lang=es
Y=LOGB(2,X) is the same as WA Log(x,2):
https://www.wolframalpha.com/input?i2d=true&i=log%5C%2840%29x%5C%2844%292%5C%2841%29&lang=es
Regards.
RE: Y=LOGB(2,X) problem - compsystems - 11-10-2024 11:48 AM
That's right, first the argument, then the base.
the 2D template of LOGb( X, b) only works on the input line, in the history it becomes linear, I hope they improve this part.
