Checking Device Info - Printable Version
+--- Thread: Checking Device Info (/thread-22730.html)
Checking Device Info - matalog - 11-19-2024 11:44 PM
I have a G2 I was trying to see the version or some details about it, so I pressed "SHIFT" then let go and pressed "Apps" (Info) Which I assumed that because the calculator is set to English language, that it would give me the result in English.
It returns a few lines of strange characters, some of which are Eastern characters.
Is this what should happen with the latest Firmware, and does anyone else get this same result?
RE: Checking Device Info - matalog - 11-19-2024 11:56 PM
This is what I get: [Image: InfoW.png?rlkey=ryx2mq0uuyu62fkvqobf63nz...p;amp;dl=1]
If I change APP it changes what I see, and most APP's have no text there.
I assume then that there is a different way to get the devices OS info.
RE: Checking Device Info - lrdheat - 11-20-2024 05:42 AM
Click on Catalogue button, call up Version. Highlight what comes up and press soft button “show” and scroll.
RE: Checking Device Info - Steve Simpkin - 11-20-2024 06:50 AM
It appears that the Info page your brought up with Blue-Shift Apps (Info) may be more of a text page where you can store information like your name, phone number etc. Just press the soft [Edit] key, backspace over or delete the characters that are there and add your own text.
RE: Checking Device Info - Arno K - 11-20-2024 01:48 PM
Hi, this INFO calls the info text that can be entered in the conkits-page for Apps, not for the device.
Arno
