HowTo print from an HP71B to the infrared printer HP 82240B ? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HowTo print from an HP71B to the infrared printer HP 82240B ? (/thread-22807.html) |
HowTo print from an HP71B to the infrared printer HP 82240B ? - floppy - 12-05-2024 08:23 AM Is any device to be used between the HP71B, I presume via HP-IL, and this printer? (since it is only controlled via infrared) RE: HowTo print from an HP71B to the infrared printer HP 82240B ? - Maximilian Hohmann - 12-05-2024 09:45 AM Hello, (12-05-2024 08:23 AM)floppy Wrote: Is any device to be used between the HP71B, I presume via HP-IL, and this printer? (since it is only controlled via infrared) You probably have already searched the forum and found this (a prototype IR interface from HP itself with schematic and assembler code from 1988): http://www.jeffcalc.hp41.eu/files/hp71_ir.pdf Obviously it was never produced in series, but with modern components it might even fit in a front module slot instead of the card reader port. Other than that I have not come across a working solution so far. Regards Max |
