Error calculating limit - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Error calculating limit (/thread-2286.html) |
Error calculating limit - jfernan751 - 10-13-2014 11:32 AM I found an error when calculating the limit of (x+e^x)^(1/x) when x->0 The result of that should be e^2 (checked ploting the function on my Prime and solving it on paper) Any idea of why could that be? Thanks in advance RE: Error calculating limit - akmon - 10-13-2014 12:03 PM I´ve just done on my calculator, on CAS mode, 6031 firmware version, and the result is inmediate: e^2. RE: Error calculating limit - jfernan751 - 10-13-2014 12:11 PM I have the same firmware version and have also done it on CAS mode but it keeps returning 1 instead of e^2 RE: Error calculating limit - jfernan751 - 10-13-2014 12:13 PM Alright, syntax error, my bad. Thanks akmon. RE: Error calculating limit - Aries - 10-13-2014 12:45 PM The entire expression must be inside the parentheses ;-) |
