20b or 30b for WP34s - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: 20b or 30b for WP34s (/thread-2438.html) |
20b or 30b for WP34s - Elite - 11-16-2014 06:33 PM Hello, I was wondering whether to choose a 20b or 30b for converting the calculator to a WP34s. What would the reasons the be to pick one over the other? Thanks in advance. Elite RE: 20b or 30b for WP34s - Nigel (UK) - 11-16-2014 07:22 PM (11-16-2014 06:33 PM)Elite Wrote: Hello, The 30b has a better keyboard - it has a firm "click" feel to it. The 20b keyboard has no click and feels a little soggy. On the other hand, on some 30b machines some keys can "click" without registering a press, sometimes. You may feel happier with a non-click keyboard that forces you to push firmly. The 20b is black, which makes for a neater appearance when the black overlay is applied. I believe that neither machine is being manufactured any longer. I have found it easier to get hold of the 30b here in the UK than the 20b. Apart from the keyboard and the case colour I believe that the hardware in both machines is identical. I prefer the look and feel of the 30b myself. I think most will agree with me. Good luck with the WP34s. You'll love it! Nigel (UK) RE: 20b or 30b for WP34s - Elite - 11-16-2014 07:31 PM Thanks, It's just that where I live, Germany, the 20b is three euros cheaper than the 30b. In the manual it also says that, however on pictures the keybords look the same. I think Ill just go with the 30b. Elite RE: 20b or 30b for WP34s - Marcus von Cube - 11-17-2014 06:43 PM There must be a hidden feature in both machines that allows HP's original firmware to detect the hardware it is running on. The enhanced features of the 30b aren't available on the 20b even if you load the 30b flash image on it. RE: 20b or 30b for WP34s - PANAMATIK - 11-18-2014 04:22 AM How did you load a 30b Flash Image into a 20b or vice versa? Can you revert a WP34S into a 30b again? RE: 20b or 30b for WP34s - Marcus von Cube - 11-18-2014 03:25 PM (11-18-2014 04:22 AM)PANAMATIK Wrote: How did you load a 30b Flash Image into a 20b or vice versa? Can you revert a WP34S into a 30b again? You just need the correct flash image. RE: 20b or 30b for WP34s - PANAMATIK - 11-18-2014 10:14 PM AFAIK you cannot read the original flash image from the 30b calculator, because it is protected. Perhaps somebody has found a way of reading it though. This would be interesting. Anyway, I do not intent to re-repurpose my WP34S. Bernhard RE: 20b or 30b for WP34s - Marcus von Cube - 11-19-2014 05:43 PM (11-18-2014 10:14 PM)PANAMATIK Wrote: AFAIK you cannot read the original flash image from the 30b calculator, because it is protected.In order to get access to the flash contents you'll need to reactivate the SAM-BA boot loader of the chip. The original firmware does not support this. I don't know whether the access path through the JTAG connector is blocked. IIRC, one of the configuration bits of the Atmel chip can be used to lock out JTAG access to the flash. Luckily, we have friends to help us out... RE: 20b or 30b for WP34s - Han - 11-21-2014 07:19 PM (11-17-2014 06:43 PM)Marcus von Cube Wrote: There must be a hidden feature in both machines that allows HP's original firmware to detect the hardware it is running on. The enhanced features of the 30b aren't available on the 20b even if you load the 30b flash image on it. On the HP50G, HP49G+, HP49G, and HP48GII, there is an opcode that behaves differently on each machine with allows assembly software to detect the type of machine. Perhaps something similar exists for these calculators? RE: 20b or 30b for WP34s - workspace - 11-22-2014 08:40 AM For my understanding, there is the same Atmel processor in the 20b and in the 30b,so same opcodes there (?) ... Just my 2cents Best regards Ralf RE: 20b or 30b for WP34s - Paul Dale - 11-22-2014 08:43 AM (11-22-2014 08:40 AM)workspace Wrote: For my understanding, there is the same Atmel processor in the 20b and in the 30b,so same opcodes there (?) ... Just my 2cents This is correct, the difference lies elsewhere. There is some ROM in the CPU which might be different, there might be something different on the PCB. - Pauli RE: 20b or 30b for WP34s - Tim Wessman - 11-25-2014 12:26 AM (11-22-2014 08:43 AM)Paul Dale Wrote: There is some ROM in the CPU which might be different, there might be something different on the PCB. Two crossed pins under the epoxy blob. |
