Programming problem with graphics - ww63 - 11-21-2014 01:30 PM
Hello i've tried a short Programm, to display a analog clock on the screen:
#pragma mode( separator(.,;) integer(h32) )
EXPORT Uhr()
LOCAL Tm,Hr,Mn,Sc,Mm,Ll;
RECT(G0);
REPEAT
Tm := approx(Time);
Hr := 2*π*(Tm MOD 12)/12;
Mn := FP(Tm)*60;
Sc := FP(Mn)*60;
RECT(G1);
FOR Mm FROM 0 TO 59 STEP 1 DO
IF Mm MOD 5 == 0 THEN
Ll := 8;
ELSE
Ll := 4;
LINE_P(G1,ROUND(160+SIN(2*π*Mm/60)*(120-Ll),0),ROUND(120-COS(2*π*Mm/60)*(120-Ll),0),ROUND(160+SIN(2*π*Mm/60)*(120),0),ROUND(120-COS(2*π*Mm/60)*(120),0),RGB(192,192,192))
LINE_P(G1,160,120,ROUND(160+SIN(Hr)*60,0),ROUND(120-COS(Hr)*60,0),RGB(0,0,0));
LINE_P(G1,160,120,ROUND(160+SIN(2*π*Mn/60)*80,0),ROUND(120-COS(2*π*Mn/60)*80,0),RGB(0,0,255));
LINE_P(G1,160,120,ROUND(160+SIN(2*π*Sc/60)*100,0),ROUND(120-COS(2*π*Sc/60)*100,0),RGB(255,0,0));
BLIT_P(G0,0,0,320,240,G1,0,0,320,240);
UNTIL GETKEY ≥ 0;
FREEZE;
but it won't display anything.
Edit: first it has dipslayed the clock, but after a few tries and minor changes it stopped working.
RE: Programming problem with graphics - Han - 11-21-2014 03:37 PM
You never declared the size of G1. So you're pretty much drawing into nothing, and then copying nothing into G0. Insert DIMGROB_P(G1,320,240) at the top and your clock works as it should.
RE: Programming problem with graphics - ww63 - 11-21-2014 03:55 PM
many thanks, i will try that.
RE: Programming problem with graphics - DrD - 11-21-2014 05:00 PM
No expert but, using just G0, and something like this could be a start:
EXPORT Uhr()
LOCAL fs,fm,fh; // flag to redraw clock hands
RECT(G0);
// Draw clock face
Ll := 8;
ELSE
Ll := 4;
LINE_P(G0,ROUND(160+SIN(2*π*Mm/60)*(120-Ll),0),ROUND(120-COS(2*π*Mm/60)*(120-Ll),0),ROUND(160+SIN(2*π*Mm/60)*(120),0),ROUND(120-COS(2*π*Mm/60)*(120),0),RGB(192,192,192));
// Initialize time flags (hand redraws)
Tm := approx(Time);
fh:=FLOOR(2*π*(Tm MOD 12)/12);
fm:=FLOOR(FP(Tm)*60);
fs:=FLOOR(FP(Tm)*60^2);
// Update real time
REPEAT
Tm := approx(Time);
Mn := FP(Tm)*60;
Sc := FP(Mn)*60;
// RECT(G1);
// Manage clock hands
IF FLOOR(Hr)==fh then
LINE_P(G0,160,120,ROUND(160+SIN(fh)*60,0),ROUND(120-COS(fh)*60,0),RGB(0,0,0)); // Draw Hour hand
ELSE
LINE_P(G0,160,120,ROUND(160+SIN(fh)*60,0),ROUND(120-COS(fh)*60,0),RGB(255,255,255)); // Clear Hour hand
fh:=FLOOR(Hr); // Reset flag
IF FLOOR(Mn)==fm then
LINE_P(G0,160,120,ROUND(160+SIN(2*π*fm/60)*80,0),ROUND(120-COS(2*π*fm/60)*80,0),RGB(0,0,255)); // Draw Minute hand
ELSE
LINE_P(G0,160,120,ROUND(160+SIN(2*π*fm/60)*80,0),ROUND(120-COS(2*π*fm/60)*80,0),RGB(255,255,255)); // Clear Minute hand
fm:=FLOOR(Mn); // Reset flag
IF FLOOR(Sc)==fs then
LINE_P(G0,160,120,ROUND(160+SIN(2*π*fs/60)*100,0),ROUND(120-COS(2*π*fs/60)*100,0),RGB(255,0,0)); // Draw Second hand
ELSE
LINE_P(G0,160,120,ROUND(160+SIN(2*π*fs/60)*100,0),ROUND(120-COS(2*π*fs/60)*100,0),RGB(255,255,255)); // Clear old Second hand
fs:=FLOOR(Sc); // Reset flag
UNTIL GETKEY ≥ 0;
FREEZE;
