Calling a Program from Home Page. What's Wrong - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Calling a Program from Home Page. What's Wrong (/thread-2595.html) |
Calling a Program from Home Page. What's Wrong - bobkrohn - 12-10-2014 07:32 AM New user. Wrote my first program. Catesian Coord System P2RN - Polar 2 Rectangular North Coordinate A = Azimuth D = Distance Return a difference in Northing ================== EXPORT P2RN(A,D) BEGIN // LOCAL N; N:=COS(A)*D; RETURN N; END; ================== Run this "P2RN(45,100)" from the Home Screen and get: "Error: Syntax Error" Have tried using variables for input after storing values into them. Can't call "P2RN(45,100)" from another program either. Works with "Run" in program Editor however. what am I doing wrong? RE: Calling a Program from Home Page. What's Wrong - Gilles - 12-10-2014 09:25 AM Hi ! I dont have my HPPrime here and perhaps this is not the problem. But I think these are good practices : 1/ Avoid ' LOCAL N; ' declaration : A..Z variables are global and predefined by default as reals. If you want local variables prefer lower case: LOCAL n; 2/ In my opinion, avoid to use global variables as parameters. The code becomes : Code:
Note that Code:
or even Code:
are simpler and does the job RE: Calling a Program from Home Page. What's Wrong - Tim Wessman - 12-10-2014 03:45 PM (12-10-2014 07:32 AM)bobkrohn Wrote: Run this "P2RN(45,100)" You running in RPN mode? Try 45 100 P2RN ENTER - possibly 45 100 P2RN(2) RE: Calling a Program from Home Page. What's Wrong - CR Haeger - 12-10-2014 04:29 PM Congrats on starting to program the Prime! If you are after short programs/scripts, consider creating it in CAS. P2RN(a,d):=approx(d*cos(a)) Which will show up in Vars/CAS/Program. Now, in: CAS: P2RN(45,100) gives 70.71 Home: P2RN(45,100) gives " Home (RPN): 45 100 P2RN(2) gives " I used approx() as I assume you dont want symbolic exact answers. Have fun. RE: Calling a Program from Home Page. What's Wrong - bobkrohn - 12-11-2014 05:12 AM I tried changing all the variables. ex. "A" changed to "Azimuth" Still getting the same error message when run in Home. Works fine when "Run" in Program Editor. Syntax Check doesn't find any problem. Just tried it in CAS and it works. I'm in Algebraic Mode if that makes a diff. And still a problem when called from another program. There shouldn't be but maybe there is some setting somewhere that's causing the problem? RE: Calling a Program from Home Page. What's Wrong - bobkrohn - 12-11-2014 11:21 AM In Emulator (will also try on calculator later) In non-CAS EXPORT P2RN(a,d)__________[DOES NOT WORK] BEGIN RETURN COS(a)*d; END; EXPORT test1(a,d)__________[works OK] BEGIN RETURN COS(a)*d; END; EXPORT test1(A,D)__________[works OK] BEGIN RETURN COS(A)*D; END; EXPORT test1(A,D)__________[works OK] BEGIN LOCAL N; N:=COS(A)*D; RETURN N; END; I just can't believe the HP-Prime operating system is this horribly buggy. Inexcusable. What other crazy problems are there yet to be discovered? Especially since it's been on the market this long. Of course I've always had this quirk of, right off the bat, being able to discover bugs in software. And it's not just using the variable "P2RN" for a program. Several other names cause a problem. Having a number in second position? Maybe it's interpreting it as P*2*RN ? Who knows. ____(try typing "P2RN" into the HOME screen) Using "PRN" works. Wait, "PR2N" doesn't work either. Ahhh. "PRN2" works. So maybe if there is a number in the name it has to be in the last position?? Hey, "P_RN" works. Crazy. RE: Calling a Program from Home Page. What's Wrong - Snorre - 12-11-2014 11:52 AM That's strange: I've tested Code: EXPORT P2RN(a,d) BEGIN COS(a)*d END; Is there any other program on your calc which has defined an exported variable or function named "P2RN"? You may try the full name: <PROGNAME>.P2RN(...). RE: Calling a Program from Home Page. What's Wrong - DrD - 12-11-2014 12:12 PM Code: EXPORT P2RN(a,d) Works fine here. Did you try 'restart' to clear vars? Also, (after an emulator back up): Calculator | Reset, may be helpful. RE: Calling a Program from Home Page. What's Wrong - DrD - 12-11-2014 12:41 PM (12-10-2014 07:32 AM)bobkrohn Wrote: New user. Your entire program is viewed as a comment, and hence doesn't execute. If you remove the "====" in both places, and remove the "//" to uncomment the program, it runs fine. This is more clearly seen (in the conn kit), if you copy / paste the code you've shown here, into the emulator over a "new" P2RN Program. Conversely, you can keep the ==='s if you place "//" comment symbols before them, accordingly: Code:
RE: Calling a Program from Home Page. What's Wrong - bobkrohn - 12-12-2014 08:44 AM The "====" where not actually in the program. I just cosmetically added them in my posting, sorry. According to the manual the "\\" only comment out the line they are on. There is no end-of-line ";" required either. _______ "Is there any other program on your calc which has defined an exported variable or function named "P2RN"? You may try the full name: <PROGNAME>.P2RN(...). " No _______ "Did you try 'restart' to clear vars? Also, (after an emulator back up): Calculator | Reset, may be helpful." I'll try that next. "Check for update" didn't find anything. The place to see where to find the firmware version on my calculator is apparently in Connectivity Pgm, HP-Prime, Properties? Application Version = 20131125 v5447 Operating System Version = V0.030.5447 Emulator Application Version = 20130331 v6031 Searched the User Manual for "Version" and "firmware" didn't see anything relevant. So can't do it on calculator. Just today something weird happened. Apparently the calculator had some sort of crash and locked up. I used a pin to reset it. All programs were still there. What was unusual was the Booting Screen was one I had not seen before. I was an artistically rendered/printed equation something like "x2 + y2 = r2" The background was a grid pattern. Also, I think some of the programs I'd deleted or renamed came back. _______ Am I correct in saying there is no way to copy ALL programs on the physical calculator, en masse, over to the Virtual Calculator? And vice-versa. (click first-file / shift-click last-file / Copy / Paste to Folder) That I have to Create/Copy/Paste each one-at-a-time? _______ Still trying to find a way to Export a Spreadsheet and/or Matrix to my PC via the Connectivity Program. Maybe even as a simple ASCII CSV file. (click first-cell / shift-click last-cell / Copy / Paste to into Text Editor or Excel on PC) _______ One good thing is that all this is very mentally absorbing. Sorry for all the questions. RE: Calling a Program from Home Page. What's Wrong - DrD - 12-12-2014 12:25 PM If, in the conn kit, you see your physical device, just create a 'back up' the physical device. Then, on the virtual device, you can 'restore' from that (physical device) 'back up' file just created. Quote:The "====" where not actually in the program. After I copy/pasted the code (from your first post) into the virtual calc, via the conn kit, your entire program was a single comment line. This may be an artifact from the way it was posted, but, as such, it does not run. As to why P2RN(45,100) failed, after removing the "====" surrounding the program, as well as the "//", the program compiled without error. P2RN(45,100) worked fine on the virtual calc. Hopefully, you've discovered the problem and moved on. RE: Calling a Program from Home Page. What's Wrong - Snorre - 12-12-2014 01:00 PM (12-12-2014 08:44 AM)bobkrohn Wrote: According to the manual the "\" only comment out the line they are on.Correct (but "//" instead of "\\"). (12-12-2014 08:44 AM)bobkrohn Wrote: There is no end-of-line ";" required either.Correct, trailing ";" is required only for statements (and can be omitted for an expressions if it's the last within a block). (12-12-2014 08:44 AM)bobkrohn Wrote: Searched the User Manual for "Version" and "firmware" didn't see anything relevant.Press "Help" button, then softmenu "Tree", then treeitem "About HP Prime", and finally softmenu "OK". You'll see the software version: <date> (<build number>). (12-12-2014 08:44 AM)bobkrohn Wrote: I was an artistically rendered/printed equation something like "x2 + y2 = r2"That's normal while restarting. You should have seen this picture the first time You switched on Your newly bought device. (12-12-2014 08:44 AM)bobkrohn Wrote: Am I correct in saying there is no way to copy ALL programs on the physical calculator, en masse, over to the Virtual Calculator? And vice-versa.No, in Connectivity Kit right-click on your source device, select "copy from here", right-click on your target device, select "copy to here". After that, both devices should contain the same data (history, apps, programs, vars, notes etc.). (12-12-2014 08:44 AM)bobkrohn Wrote: Still trying to find a way to Export a Spreadsheet and/or Matrix to my PC via the Connectivity Program.Open Your spreadsheet in Connectivity Kit, select the whole sheet, copy, paste into Excel. You'll lose the formatting and may need to correct some function names or decimal signs (in my case Excel functions have German names like "SUMME" instead of "SUM", and numbers have an other decimal sign). Some spreadsheet objects and functions (e.g. complex numbers, matrices within cells, CAS-functions) may not work in Excel. (12-12-2014 08:44 AM)bobkrohn Wrote: Sorry for all the questions.You're welcome. RE: Calling a Program from Home Page. What's Wrong - bobkrohn - 12-18-2014 07:14 AM Just upgraded to the new firmware. Dec 03 2014 Still has the bug with using a number in a Function name (unless it's the last character) Yup absolutely a valid bug. RE: Calling a Program from Home Page. What's Wrong - Snorre - 12-18-2014 12:41 PM Hi Bobkrohn, I could reproduce the error you described. This occurres if the current app is "Spreadsheet": "P2RN(A,D)" throws an error since "P2RN" is interpreted as "P2*R*N" (as if P2 was a cell name). If I choose another app (e.g. "Functions"): "P2RN(A,D)" will call the so named program function. Could you check that on your device? RE: Calling a Program from Home Page. What's Wrong - Tim Wessman - 12-18-2014 02:49 PM (12-18-2014 12:41 PM)Snorre Wrote: I could reproduce the error you described. If you are correct, then looks like implicit multiplication has reared its ugly head again... :-( RE: Calling a Program from Home Page. What's Wrong - Gilles - 12-18-2014 09:37 PM (12-18-2014 02:49 PM)Tim Wessman Wrote:(12-18-2014 12:41 PM)Snorre Wrote: I could reproduce the error you described. It works fine for me with the rev 6975 both with virtual and real calc. EDIT:Same as Snore, I get an error if the current app is "Spreadsheet" RE: Calling a Program from Home Page. What's Wrong - DrD - 12-18-2014 11:25 PM [Home View] Spreadsheet app, P2RN(45,100) returns syntax error. Cursor just inside opening paren. RE: Calling a Program from Home Page. What's Wrong - bobkrohn - 12-19-2014 05:18 AM You have Sharp Eyes Snorre! I would never have figured that out. Yes, I have Spreadsheet active. RE: Calling a Program from Home Page. What's Wrong - Tim Wessman - 12-19-2014 03:29 PM (12-19-2014 05:18 AM)bobkrohn Wrote: Yes, I have Spreadsheet active. Ok, now that you've isolated a root cause I've put this on the list of things to look at. Thanks! |
