RANDOM and CAS - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: RANDOM and CAS (/thread-2615.html) |
RANDOM and CAS - Helge Gabert - 12-13-2014 06:28 PM In CAS, RANDOM(), with three arguments, appears to be only working for lists of size 11 or less, e..g. RANDOM(11,0,10) OK RANDOM(12,0,10) "Error: Invalid dimension." No problem in Home! This is with firmware 6940 (now pulled). Not sure if this was OK in the previous firmware. RE: RANDOM and CAS - parisse - 12-14-2014 07:21 AM RANDOM in CAS with 3 args n,a,b does not the same as in Home. In CAS, you take n integer values between a and b but once the value has been selected you can not get it again (in contrast with randvector). For example, RANDOM(11,0,10) is a permutation and RANDOM(12,0,10) is indeed invalid dimension. In Home, it seems you take 11 floating point values between 0 and 10. RE: RANDOM and CAS - Gerald H - 12-14-2014 09:52 AM (12-13-2014 06:28 PM)Helge Gabert Wrote: In CAS, RANDOM(), with three arguments, appears to be only working for lists of size 11 or less, e..g. Bug confirmed, also with the new debugged & withdrawn version. RE: RANDOM and CAS - Marcus von Cube - 12-14-2014 10:32 AM (12-14-2014 09:52 AM)Gerald H Wrote:It's a case problem. If you type "random" instead of RANDOM then you get the Home behavior in CAS. If you type RANDOM you see the error.(12-13-2014 06:28 PM)Helge Gabert Wrote: In CAS, RANDOM(), with three arguments, appears to be only working for lists of size 11 or less, e..g. RE: RANDOM and CAS - Helge Gabert - 12-14-2014 04:05 PM Yes, it is a case error, I agree. There needs to be "random" in the catalog. Also, it should be made clear in the help catalog that RANDOM in CAS works (but as a permutation without replacement), and an entry for "randvector" is due. |
