Advanced Graphing ? - Printable Version
+--- Thread: Advanced Graphing ? (/thread-2666.html)
Advanced Graphing ? - lrdheat - 12-19-2014 04:55 PM
Another graphing area question...how would I plot area in advanced plot app of MAX(SIN(X),COS(X)) ?
RE: Advanced Graphing ? - Snorre - 12-19-2014 05:28 PM
I'd say you should do it with the "Function" app by plotting F1(X)= "MAX(SIN(X),COS(X))".
But maybe you're more interested in the "Advanced Graphing" of V1: "SIN(X)>COS(Y)" and V2: "SIN(X)<COS(Y)".
It depends on what your intention is.
Greetings
RE: Advanced Graphing ? - Han - 12-19-2014 05:38 PM
Did you mean to shade in the area between the x-axis and the function max(cos(x),sin(x))? If so, then define F1 as MAX(SIN(X),COS(X)) and then in the advanced graphing app use:
V1: Y \( \ge \) F1(X) AND Y\(\le \) 0
V2: Y \(\le \) F1(X) AND Y \( \ge \) 0
Edit: If you want them to be of the same color (say using V1's color), then do:
V2(COLOR):=V1(COLOR);
RE: Advanced Graphing ? - lrdheat - 12-19-2014 09:08 PM
Hi Han,
I wanted to get the area under MAX(SIN(X),COS(X)) in the advanced function graphing app so that I could go to table and easily find "X" values that produce specified areas. This can be accomplished in the regular function app by subtracting a specific value for area using AREA(MAX(SIN(X),COS(X))-"specific area", and using function analysis to find root.
I wanted to have an easier way to query "x" values for a variety of specific areas by creating a table from the advanced graphing app.
RE: Advanced Graphing ? - Snorre - 12-19-2014 10:51 PM
Hello lrdhead,
Am I right, that you want for any arbitrary area a to find an x(a), so that
\[ a=\int_0^x \max(\sin\theta,\cos\theta)d\theta \]
If so, I haven't found a solution you might want, since I couldn't get "Advanced Graphing" to plot anything involving areas/integrals.
You could plot that in "Function" app (patience!), and then look at the numeric table. But this is driven by the step of x, not a(x).
Another way is using the "Solver" app.
1st: enter your problem; 2nd: solve x for a given a; 3rd: plot
[attachment=1320][attachment=1321][attachment=1322]
Sorry, that's not the nice tabular solution (a vs. x(a)) you may expect
