CASette IO Utilities updated - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: CASette IO Utilities updated (/thread-2708.html) |
CASette IO Utilities updated - Marcus von Cube - 12-25-2014 12:37 PM I've updated my CASette IO Utilities. Some programs now support Unicode (UTF-8) input an output. Here is an example from list850: Code: Program (ASCII): "charpb7.TXT" Code F0 is originally the multiplication sign (×) but this would break the communication protocol to the PB-700 and is therefore silently replaced with '*' by the bas850 compiler. For those of you who own an HP Jornada 720: You can now run the utilities in the command window of your Windows CE handheld. RE: CASette IO Utilities updated - jebem - 01-02-2015 11:16 PM Thanks, Marcus! RE: CASette IO Utilities updated - Marcus von Cube - 01-09-2015 03:34 PM A minor update is online. bas850 can now create data files (some testing required!) RE: CASette IO Utilities updated - Marcus von Cube - 01-14-2015 05:53 PM (01-09-2015 03:34 PM)Marcus von Cube Wrote: A minor update is online. bas850 can now create data files (some testing required!) I did some testing. The result is another update to list850 and bas850. The download is updated. |
