Connectivy Kit - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Connectivy Kit (/thread-2709.html) |
Connectivy Kit - Tyann - 12-25-2014 12:38 PM Hello The logicel Connectivy Kit refuses to install on my Vista PC . I get an error 0x800b010a . Is it compatible ? RE: Connectivy Kit - timetraveller - 12-26-2014 12:39 PM Sorry to hear of your troubles. First, I'd try installing under Administrative privileges. Right click the installing program and choose Run As Administrator. Otherwise, Microsoft has quite a bit of information on this error code on their MSDN site: http://msdn.microsoft.com/en-us/library/windows/desktop/jj835836(v=vs.85).aspx Looks like a complicated problem with trusted install certificates. Good luck. Bill RE: Connectivy Kit - Tim Wessman - 12-30-2014 01:04 AM (12-25-2014 12:38 PM)Tyann Wrote: Hello Yes, it should be compatible. This is the first "install error" I've heard of yet. Were you able to figure it out? RE: Connectivy Kit - Tyann - 12-30-2014 08:03 AM There seems to be a certificate problem ! |
