freeze problem - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: freeze problem (/thread-2761.html) |
freeze problem - aldozuya - 12-31-2014 01:34 PM hi everyone! i have a problem with my hp prime after update the firmware the calculator is freeze, and i can't restore the calculator, i try to reset from the switch in the back side but the calculator show the equation of the circle and maintain this condition (calculator freeze with the equation of circle) i ask apologies, my english is very poor thank you all RE: freeze problem - Helge Gabert - 12-31-2014 04:26 PM Start the ConnKit, plug in the USB cable, and hold Symb and reset (at the back of the calc) at the same time. That should force the Prime into update. I had the same problem, and that worked for me. RE: freeze problem - aldozuya - 01-02-2015 01:42 AM no help, the next monday i'll take my calculator to the HP store i try with CFO, apps+esc+on there are methods neither works thanks for your time Helge |
