How to create a table - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Forum Issues and Administration (/forum-19.html) +--- Thread: How to create a table (/thread-288.html) |
How to create a table - Thomas Klemm - 12-31-2013 07:21 AM In a recent thread I tried to create a table: 10: 1.291303564 20: 1.291290482 50: 1.291286729 100: 1.291286183 200: 1.291286042 500: 1.291286006 1000: 1.291285997 For this I used the Unicode character NO-BREAK SPACE U+00A0. Is there a simpler way to create a table? Even in a code-block multiple spaces are sometimes ignored: Code:
Maybe there's a plug-in for tables? RE: How to create a table - Katie Wasserman - 12-31-2013 05:09 PM Quote:Maybe there's a plug-in for tables? There is! Actually a few of them are described in this this thread. Dave, what do you think? RE: How to create a table - Mark Hardman - 12-31-2013 05:29 PM (12-31-2013 07:21 AM)Thomas Klemm Wrote: In a recent thread I tried to create a table: You could also create the table as a LaTex expression:
\[\begin{matrix}
Mark Hardman
10: & \underline{1.291}303564 \\ 20: & \underline{1.2912}90482 \\ 50: & \underline{1.29128}6729 \\ 100: & \underline{1.29128}6183 \\ 200: & \underline{1.29128}6042 \\ 500: & \underline{1.29128}6006 \\ 1000: & \underline{1.291285997} \end{matrix}\] RE: How to create a table - Dave Hicks - 01-02-2014 03:18 PM PHP Code: Strange Odd... The PHP blocks get the formatting right, except for the first line, though the PHP syntax coding might bother you. Then again, maybe it won't be that big of a deal for what you are posting. You might give that a try. I think it will be easy to remove the PHP colors. I'll see if anything can be done to help out the standard code blocks as well. It will be a few days before I can do anything significant. Holiday visits to relatives and ice storms, power outages and staying in homes of strangers has put me well-behind on everything. RE: How to create a table - Katie Wasserman - 01-02-2014 04:54 PM You can also use a begin{align} / end{align} block in LaTex when you have an even number of columns. For example: \( \begin{align} 1 & 2 & 3 & 4 \\ left & right & left & right \\ 1 & 1 & 3 & 9 \\ 2 & 4 & 4 & 16 \\ not & every & row & has \\ to & use & all & columns \\ 3rd & row \\ & & 4th & row \end{align}\) I think this looks better than using a matrix. Here's the original example: \(\begin{align} 10: & \underline{1.291}303564 \\ 20: & \underline{1.2912}90482 \\ 50: & \underline{1.29128}6729 \\ 100: & \underline{1.29128}6183 \\ 200: & \underline{1.29128}6042 \\ 500: & \underline{1.29128}6006 \\ 1000: & \underline{1.291285997} \end{align}\) RE: How to create a table - Thomas Klemm - 01-02-2014 10:45 PM (01-02-2014 04:54 PM)Katie Wasserman Wrote: \(\begin{align}That looks great! Thanks for your suggestion. I'll stick to that for the moment. But not all forum members are familiar with \(\LaTeX\). Cheers Thomas RE: How to create a table - Dave Hicks - 01-08-2014 05:59 AM I've made adjustments to the code block code so these should all line up now: Code: 1.0 OK - that looks good. RE: How to create a table - Thomas Klemm - 03-14-2015 08:52 AM Displaying a table of information Quote:This example shows how you can get a table rendered via bbcode using the [table], [tr], [td] and [th] tags. This doesn't appear to work: [table] [tr] [th]Name[/th] [th]Age[/th] [/tr] [tr] [td]John[/td] [td]65[/td] [/tr] [tr] [td]Gitte[/td] [td]40[/td] [/tr] [tr] [td]Sussie[/td] [td]19[/td] [/tr] [/table] Cheers Thomas RE: How to create a table - matthiaspaul - 03-18-2015 11:29 PM (03-14-2015 08:52 AM)Thomas Klemm Wrote:I don't know about MyBB, but in the forum I maintain these BBCodes are not part of the standard repertoire but need to be implemented as Custom BBCodes by the site admin. It's straight forward for IPB. I guess, the MyBB software provides a similar facility.Quote:This example shows how you can get a table rendered via bbcode using the [table], [tr], [td] and [th] tags.This doesn't appear to work: In my experience, however, only advanced members manage to use them correctly. The outcome might be different in a forum about calculators, though. ;-) Greetings, Matthias RE: How to create a table - Katie Wasserman - 03-19-2015 12:30 AM (03-14-2015 08:52 AM)Thomas Klemm Wrote: Displaying a table of information Take a look at this thread. Your table would be: \begin{array}{|c|c|} \hline Name & Age \\\hline John & 65 \\\hline Gitte & 40 \\\hline Sussie & 19 \\\hline \end{array} RE: How to create a table - Marcus von Cube - 03-19-2015 04:11 PM here is Katie's code: Code: \begin{array}{|c|c|} RE: How to create a table - Dave Hicks - 03-21-2015 05:27 PM While I probably could add HTML-like tables like Thomas suggested, I was a little leery of doing this since people seem to mess up with them a lot. I also prefer not to mess with the base code too much since things may have to be reintegrated into future updates. And I thought that people were happy with the latex way of doing it. But if there are problems with the latex solution, I could look into this again. RE: How to create a table - matthiaspaul - 03-22-2015 11:43 PM (03-21-2015 05:27 PM)Dave Hicks Wrote: But if there are problems with the latex solution, I could look into this again.Hm, while I understand that LaTeX is nice to have in a calculator and math related forum, as a maintainer I would be seriously worried about depending on any external resources and using services not hosted locally on the own server - in our forum I maintain a strict anti-cross-site-scripting policy and independance from any client-side scripting for security/privacy reasons. After all, why should a third-party like mathjax.org be able to track visitors of this forum and collect data about them? Doesn't MyBB provide menus to define Custom BBCodes from the admin console? While this would not be as flexible as what would be possible with PHP, at least in IPB it's powerful enough for tables, and defined this way, they should survive software upgrades as well. Greetings, Matthias RE: How to create a table - Thomas Klemm - 03-23-2015 08:31 PM (03-19-2015 12:30 AM)Katie Wasserman Wrote: Your table would be: Thanks Katie, for your excellent suggestion! (03-21-2015 05:27 PM)Dave Hicks Wrote: And I thought that people were happy with the latex way of doing it. I'm happy with the solution provided by LaTeX. I was just curious whether this example from BBCode works. There's even a disclaimer: Quote:Doesn't work? Thus I wasn't much surprised. Cheers Thomas |
