Backing up Prime programs AND VARIABLES - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Backing up Prime programs AND VARIABLES (/thread-294.html) |
Backing up Prime programs AND VARIABLES - veeblefester - 01-01-2014 11:19 AM The 50g has the ARCHIVE command that backs up everything with one command, either internally or externally. How does one do this with the Prime? I see no way to archive ALL user variables. Thanks in advance for any help. RE: Backing up Prime programs AND VARIABLES - jgreenb2 - 01-01-2014 03:35 PM Try the backup command in the connectivity kit. Not sure if it saves everything. RE: Backing up Prime programs AND VARIABLES - debrouxl - 01-01-2014 04:56 PM The connectivity kit, and libhpcalcs, support a backup operation, which makes the calculator send all of its programs, notes, real numbers, complex numbers, lists, matrices, settings (CAS and non-CAS, exam testing mode), and several other file types. RE: Backing up Prime programs AND VARIABLES - Michael de Estrada - 01-01-2014 08:23 PM (01-01-2014 04:56 PM)debrouxl Wrote: The connectivity kit, and libhpcalcs, support a backup operation, which makes the calculator send all of its programs, notes, real numbers, complex numbers, lists, matrices, settings (CAS and non-CAS, exam testing mode), and several other file types. It will not, however, save User variables and User defined functions. |
