[WP 34S] I finally bricked it :-( - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: [WP 34S] I finally bricked it :-( (/thread-2985.html) |
RE: [WP 34S] I finally bricked it :-( - walter b - 11-08-2015 08:37 PM (11-07-2015 01:37 PM)Marcus von Cube Wrote: When MySamba is interrupted midway then the boot bit has already been set and the SAM-BA loader is no longer active. You will need to ERASE again before you can reflash.(emphasis added) John or Josh (or whoever else thinks he's killed a machine), Could you please try this with one of your 'dead' machines? Is resurrection possible this way? d:-? RE: [WP 34S] I finally bricked it :-( - jayemel - 11-08-2015 09:08 PM Marcus and Walter, No, I've tried to erase numerous times to no avail. Regards, -- Josh |
