Line integral, jacobian... - Printable Version
+--- Thread: Line integral, jacobian... (/thread-2992.html)
Line integral, jacobian... - salvomic - 02-02-2015 08:56 PM
hi all,
I need some hints to use with Prime:
curve integral (for scalar function by a curve)
line integral (vectorial camp by a curve)
flux integral
and also something to treat with Jacobian Matrix (where line are gradients).
Any programs, functions? hints to create my own program easily?
Thank a lot in advance!
Salvo
RE: Line integral, jacobian... - Han - 02-02-2015 10:42 PM
(02-02-2015 08:56 PM)salvomic Wrote:  hi all,
flux integral
Salvo
You should be able to do all of these in the CAS. For example, if C is the path from (0,0) to (1,1) then C is described by \( \vec{r}(t) = t\vec{i} + t\vec{j} \) where \( 0 \le t \le 1 \). If the force F is defined by \( \vec{F} = (3x-2y)\vec{i} + (4x+1)\vec{j} \) then
\[ \int \vec{F}\cdot d\vec{r} \]
can be computed by:
r:=[t,t];
dr:=diff(r,t);
f:=[3*x-2*y, 4*x+1];
ft:=subst(f,[x,y]=r);
int(dot(ft,dr),t,0,1);
If \( \vec{F} \) is path-independent (i.e. a gradient field; also known as conservative fields) then one can simply apply the fundamental theorem of calculus for vectors. For example, if
\[ \mathrm{grad}(f) = 2xy \vec{i} + (x^2+8y^3)\vec{j} \]
then you can do something like:
f1:=2*x*y; f2:=x^2+8y^3;
check if we actually have a real gradient field:
diff(f1,y) - diff(f2,x);
(simplify if needed; gradient field means difference should be 0). If we have a gradient field, i.e. \( \vec{F} = \mathrm{grad}(f) \), then we can find f by:
f:=int(f1,x);
dg:=diff(f,y)-f2;
g:=int(dg,y);
f:=simplify(f+g); // can optionally leave out simplify()
p:=[0,0];
q:=[1,1];
subst(f,[x,y]:=q)-subst(f,[x,y]=p);
Edit: A CAS program is really nothing more than copying the manual commands you use in the CAS view into a CAS-program, and making some minor edits and slapping #cas and #end around everything. So I recommend playing around with the CAS view, and once you have what you want, copy it into a program.
RE: Line integral, jacobian... - salvomic - 02-02-2015 11:05 PM
(02-02-2015 10:42 PM)Han Wrote:  You should be able to do all of these in the CAS. For example, if C is the path from (0,0) to (1,1) then ...
thank you, Han, for this clear explanation. I'll read it again while try on CAS, and then I'll try to make one or more little program by myself, also if I'm still learning Prime's programming...
Your hint for subst() is very useful for my purpose.
Let's start...
Salvo
RE: Line integral, jacobian... - salvomic - 02-03-2015 08:55 PM
hi Han,
a little idea, following your precious advice (and thanks Snorre for a "C like" approach that's I like), to start; but these functions need some controls to avoid incorrect input and reset...
We can use two little programs:
intcur: to input scalar function (x,y,z), parametric form of a curve [r(t), r(t), r(t)], lower and high bound to get a curvilinear integral
intlin: to input vectorial function, parametric form of a curve, lower, high to get line integral...
EDIT: these programs now works with 2 or 3 components (parametric expression: [r(t), r(t), r(t)] or [r(t), r(t)])...
#cas
intcur(args):=
local argv,argc, a, b;
local f, r, dr, ft, s;
argv:=[args];
argc:=size(argv);
IF argc !=4 THEN
return "Input:f(x,y,z), [r(t),r(t),r(t)] ,low, high";
 ELSE
f:=argv(1);
r:=argv(2);
a:=argv(3);
b:=argv(4);
dr:=diff(r,t);
s:= size(argv(2));
ft:= IFTE( s==3, subst(f,[x,y,z]=r), subst(f,[x,y]=r) );
return int(dot(ft,l2norm(dr)),t,a,b);
#end
#cas
intlin(args):=
local argv, argc, a, b;
local f, r, dr, ft,s;
argv:=[args];
argc:=size(argv);
IF argc !=4 THEN
return "Input:[x,y,z], [r(t),r(t),r(t)] ,low, high";
 ELSE
f:=argv(1);
r:=argv(2);
a:=argv(3);
b:=argv(4);
dr:=diff(r,t);
s:= size(argv(2));
return int(dot(ft,dr),t,a,b);
#end
RE: Line integral, jacobian... - salvomic - 02-04-2015 02:32 PM
here my hypothesis for Jacobian Matrix function...
It should works, I hope without errors (please, see if any).
Input: [f(1), f(2), ...], [x,y,...]
Salvo
#cas
jacob(args):=
// Matrice jacobiana by Salvo MiccichÈ
// input expr vettoriale, vettore variabili
local argv, argc, mat, f, var, fn, j, k,  gr, vd;
argv:=[args];
argc:=size(argv);
IF argc !=2 THEN
return "Input:[f1(x),f1(y),f1(z)...], [x,y,z,...]";
ELSE
f:=argv(1);
var:=argv(2);
fn:=size(f);
vd:=size(var);
mat:=makemat(0,fn,vd);
FOR j FROM 1 TO fn DO // gradienti
gr:=grad(f(j),var);
FOR k FROM 1 TO vd DO // elementi
mat[j,k]:=gr(k);
END; // for k
END; // for j
return mat;
END; // if-else
#end
Now, please, help me to have a short program to calculate surface integrals and flux integral (Int(f.n)), thank you Smile
RE: Line integral, jacobian... - toshk - 09-07-2016 09:22 PM
Jacobian:
Transpose(diff(fn,[x,y,z])) or transpose(gradient([f1,f2,f3],[x,y,z])
trn(diff([x*y*z, y^2, x + z], [x, y, z]))
Laplacian:
divergence(gradient(f(x, y), [x y]),[x,y])
RE: Line integral, jacobian... - salvomic - 09-07-2016 10:35 PM
(09-07-2016 09:22 PM)toshk Wrote:  Jacobian:
Laplacian:
yes, thanks
See also here my (and Han) solutions: Linear and curvilinear - Jacobian
laplacian(Expr, Vector) is also a command inside the Prime, now...
Salvo
