Adding pic to post - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Test forum (/forum-18.html) +--- Thread: Adding pic to post (/thread-3101.html) |
Adding pic to post - rprosperi - 02-15-2015 05:13 PM FYI - Inserted photo attachments do not appear in preview mode. RE: Adding pic to post - Dave Frederickson - 02-15-2015 05:38 PM When you reply to a post with a pic do you see the pic in the post when you preview? Perhaps your preview preferences are phbbbbt! RE: Adding pic to post - Marcus von Cube - 02-15-2015 05:48 PM (02-15-2015 05:13 PM)rprosperi Wrote: FYI - Inserted photo attachments do not appear in preview mode. That's something I've noticed, too. I guess it has to do with the delayed upload of an attachment. As long as a post isn't "posted" its attachments aren't available, at least the generated URLs do not work yet. There should be a difference when you edit a post with attachments. Those which are already present in the original posting should appear on a preview as well. RE: Adding pic to post - rprosperi - 02-15-2015 05:56 PM (02-15-2015 05:48 PM)Marcus von Cube Wrote:(02-15-2015 05:13 PM)rprosperi Wrote: FYI - Inserted photo attachments do not appear in preview mode. Just tried and it's exactly as Marcus noted. I also played around a bit more and indeed it appears that attachments aren't 'seen' by the system until the message is saved. I've played with this many times, and always bailed out thinking I was doing something wrong. Dumb. That's what the test forum is for... Dumb. |
