recall a function - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: recall a function (/thread-3146.html) |
recall a function - salvomic - 02-19-2015 03:07 PM hi, please, I need hints to recall a function in the same program passing parameters. The second function of this code won't work: Code:
How to pass "u" as variable for the integral? Also ProgName.gammad() doesn't works... RE: recall a function - bobkrohn - 02-19-2015 03:32 PM use a List? L1(1):=f; L1(2):=u; RETURN L1; or just... RETURN {f,u} RE: recall a function - salvomic - 02-19-2015 03:39 PM or just... RETURN {f,u} [/quote] no, I'm not using list: my program has two functions: gammad(k,t,n) and gammad_cdf(k,t,n) from the second I want recall the first to make an integral, using u as "du". With my code I get "bad argument: ex. using gammad_cdf(7.5,1,8) the program gives "int(gammad(7.5,1,0),0,0,8) error..." (it sees u=0 but (int(gammad(7.5,1,8),u,0,8) is ok)... RE: recall a function - Han - 02-19-2015 05:02 PM Any symbolic manipulation is going to require the CAS, with exception for a few commands. To get around this, you could try: Code: EXPORT gamma_cdf(k,t,n) Sometimes it is possible to also quote an expression (e.g. 'X' vs X) although in HPPPL, quoted objects are still (generally) evaluated. RE: recall a function - salvomic - 02-19-2015 05:12 PM (02-19-2015 05:02 PM)Han Wrote: Any symbolic manipulation is going to require the CAS, with exception for a few commands. To get around this, you could try: thank you! I didn't remember that... with X it works! |
