Trouble updating Prime firmware - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Trouble updating Prime firmware (/thread-3191.html) Pages: 1 2 |
RE: Trouble updating Prime firmware - toml_12953 - 05-12-2016 01:03 PM (04-30-2016 01:06 AM)informach Wrote: Hi!: What is the Prime 1.2 firmware update they're talking about? Is that the 2016 update? Tom L RE: Trouble updating Prime firmware - informach - 05-12-2016 01:33 PM Hi!, toml_12953: This method, for communicate, across, the USB port, is available, for any version, of firmware. Kind Regards. informach. RE: Trouble updating Prime firmware - Tim Wessman - 05-12-2016 02:30 PM (05-12-2016 01:03 PM)toml_12953 Wrote: What is the Prime 1.2 firmware update they're talking about? Is that the 2016 update? No, that is the 8151 from last year. That specific problem should be resolved now. It was all about not recognizing when the device switched from the normal operation mode, to the "updater" mode. RE: Trouble updating Prime firmware - Tim Wessman - 05-12-2016 02:36 PM (05-12-2016 12:36 PM)mark4flies Wrote: I also checked preferences and discovered an unselected option to use the "new update method." Never heard about it! Glad it is back up and working for you. What was actually happening is you did use the same update method. The "new" update method only will work when you are on revision 10077 already, and into the future. This time though, the usb system didn't do something funny on the windows side the calculator wasn't expecting and so it finished properly. The new method doesn't require administrator mode to run and basically pushed the files directly to the device first, validates them, and then on reboot performs the update. Unfortunately, there was no way to start using that until you are >10000 - kind of a chicken/egg thing. RE: Trouble updating Prime firmware - cyrille de brébisson - 05-13-2016 05:14 AM Hello, The "new update method" would NOT be the reason for the success. You have never heard of it... because it's new :-). This new method avoid the use of the 'special update' software which requires administrative privileges by using application level USB messages to send the large update files, and then reboots in bootloader mode to update the calculator locally. However, this method will only work with a calculator that has the new firmware and which is running correctly. Any future FW update will be able to use it (this is NOT a future looking statement BTW and does not mean that such FW will be released, just that if it was released, it could use that method). Anyhow, I am glad that you were able to complete your update and that it is now working. I will investigate this error 14. Cyrille RE: Trouble updating Prime firmware - toml_12953 - 05-13-2016 12:56 PM (05-13-2016 05:14 AM)cyrille de brébisson Wrote: BTW and does not mean that such FW will be released, just that if it was released, it could use that method). Talk about CYA! Tom L RE: Trouble updating Prime firmware - Tim Wessman - 05-13-2016 03:44 PM (05-13-2016 05:14 AM)cyrille de brébisson Wrote: I will investigate this error 14. Error 14 was some unrecognized commands being seen with the SCSI passthrough. Later versions of the bootloader code (16, 17) work better and handle those. RE: Trouble updating Prime firmware - StephenG1CMZ - 05-13-2016 05:25 PM (04-30-2016 12:50 PM)dalupus Wrote:(04-30-2016 09:23 AM)StephenG1CMZ Wrote: To get around the USB3 problem, would connecting a USB2 hub into a USB3 port fix the problem?? Apologies...you were clear, but i had missed reading your earlier post. RE: Trouble updating Prime firmware - bobh - 05-15-2016 02:41 PM I have been remiss in updating my Prime firmware. I fear I am so far out of date that I must update to an intermediate firmware somewhere before the current. The updater on my Windows 7 usb2 sees my device and backs-up successfully but stalls in the "HP Prime recovery mode V13" when trying to update to 20160414. None of the above reset/symb gyrations seem to help. I'm at 20130813 v5105 and the current Connectivity Kit 2016 4 14 Rev 10077 Any suggestions would be appreciated. bobh RE: Trouble updating Prime firmware - informach - 05-15-2016 03:02 PM Hi!, bobh: You needed, uninstall all (Firmware, Virtual Calculator and Connectivity kit) of your previous versions and install only the ultimate 10077. Have a Power Tool call ... Advanced Unisntaller PRO (free download), from ... http://www.advanceduninstaller.com You can downoad, the version 10077, from ... http://h30434.www3.hp.com/t5/Calculators/HP-PRIME-GRAPHING-CALCULATOR-New-Firmware/td-p/5593925 Kind Regards. informach. RE: Trouble updating Prime firmware - Stevetuc - 05-21-2016 08:40 AM (05-12-2016 02:30 PM)Tim Wessman Wrote:(05-12-2016 01:03 PM)toml_12953 Wrote: What is the Prime 1.2 firmware update they're talking about? Is that the 2016 update? Tim, You mention it fixes that specific problem, but it seems not to fix all , as I still had to use a usb2 hub to get the upgrade to 10077 from 8151 to work on my usb3 equipped macbook pro ( running win7 via boot camp) Does the new update method address outstanding issues with usb3? /Steve RE: Trouble updating Prime firmware - informach - 05-21-2016 01:16 PM Hi!, Stevetuc: Apparently he should have, in the new version (10077), been solved. But it may be, that in some software, still requires, the conversion of ports. See, this link ... http://support.hp.com/us-en/document/c04674521 Kind Regards. informach. RE: Trouble updating Prime firmware - Tim Wessman - 05-23-2016 02:08 PM (05-21-2016 08:40 AM)Stevetuc Wrote: Does the new update method address outstanding issues with usb3? It should. The update is equivalent to "pushing a file" to the device and doesn't need low level writing capability, or special drivers. If the connkit works, then it should work as well. RE: Trouble updating Prime firmware - bobh - 05-28-2016 03:19 PM No luck. I tried all the steps, reinstalled all the software. Still hangs up at "HP Prime recovery mode V13" The app at "Waiting for connection" Thanks for the help but no need to answer further. I am taking the HP Prime out to the garage and smash it with a hammer. RE: Trouble updating Prime firmware - informach - 05-28-2016 03:38 PM Hi!, bobh: Please, don't destroy, your jewell !. Try, uninstall from your PC, all files of HP PRIME Firmware, what you installed. For this, you can free download and install ... Advanced Uninstaller PRO, from ... http://www.advanceduninstaller.com Clear all cookies, temporary files, register problems, erase HP PRIME installed, etc ... Now, charge of your HP PRIME, the battery to 100% of capacity of charge. Download and install, in your PC, the ultimate software version (10077), the firmware, Connectivity Kit and Virtual Calculator. Open the Conecctivity kit and connect your HP PRIME, with connector cable in any USB port. The connectivity kiy must be recognize your HP PRIME, in USB. Then find when say Actualize. Good luck !. Kind Regards. informach. RE: Trouble updating Prime firmware - Tim Wessman - 05-31-2016 03:16 PM (05-28-2016 03:19 PM)bobh Wrote: No luck. I tried all the steps, reinstalled all the software. Still hangs up at "HP Prime recovery mode V13" The app at "Waiting for connection" If you are connected on a USB 3 port, and you haven't updated to the previous version then it probably is not recognizing the switch from "normal" operation to the update mode. Here's a message I wrote a while back: Quote:Basically, the problem is most likely when the calculator "switches" from the normal opearting mode into the "updater" mode. Recently with some USB ports, windows stopped reloading the usb driver into the "updater" mode on some systems. |
