Statistic: class interval? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Statistic: class interval? (/thread-3289.html) |
Statistic: class interval? - salvomic - 03-06-2015 11:11 PM hi, I need help (or a tutorial, if there is one) to represent a table divided into "class intervals" and frequencies (or class intervals for a var and another variable, if it possible, in Statistics 1var or statistic 2var... Or hints to "disaggregate" data to analyze with Prime apps... i.e. w have x_i 0-10, 11-20, 21-30, 31-40 (intervals) n_i 1, 3, 2, 1 (frequencies) or x_1 0-10, 11-20, 21-30, 31-40 (class intervals) y_1 30, 24, 60, 22 (data) thanks Salvo RE: Statistic: class interval? - Helge Gabert - 03-07-2015 12:56 AM The built in Histogram in Stats 1Var doesn't do it? Look at H1-H5 (there is a provision for a frequency column as well). RE: Statistic: class interval? - salvomic - 03-07-2015 06:10 AM (03-07-2015 12:56 AM)Helge Gabert Wrote: The built in Histogram in Stats 1Var doesn't do it? Look at H1-H5 (there is a provision for a frequency column as well). histograms are ok and handle frequencies, but I mean: I have data in which X is expressed as class interval (ex. classes of age), I need a method to input data to calculate statistics... 0-12 3 13-24 4 25-30 6 31-40 4 ... then make statistics on X and frequencies (or, in 2var stat, also on Y)... thanks Salvo RE: Statistic: class interval? - Tim Wessman - 03-07-2015 06:27 AM Change the bin width on the plot setup screen for your histogram. Histograms are nearly always uniformly spaced and there are actually very few software packages that allow non-uniform bin widths. RE: Statistic: class interval? - parisse - 03-07-2015 07:43 AM histogram should do it (inside Geo app), an example from Xcas online help: histogram([[1.5..1.65,50],[1.65..1.7,20],[1.7..1.8,30]]) RE: Statistic: class interval? - salvomic - 03-07-2015 09:00 AM (03-07-2015 06:27 AM)Tim Wessman Wrote: Change the bin width on the plot setup screen for your histogram. (03-07-2015 07:43 AM)parisse Wrote: histogram should do it (inside Geo app), an example from Xcas online help: thank you both, I'll make some tries... I understand that it's not easy to handle this kind of problem. I thought there was a way to input something like 0..10 or 0::10. This was the sense of my question... I'll try as you suggest with some examples. However, for now, I don't find histogram in Geo; I'm searching better... Salvo |
