Return: how get two more values and two lines? - Printable Version
+--- Thread: Return: how get two more values and two lines? (/thread-3312.html)
Return: how get two more values and two lines? - salvomic - 03-08-2015 10:12 PM
How to get two line in RETURN()?
in #CAS program it works
return a, b, c;
nut with Home programs it doesn't.
I tried \n but no luck...
Thanks in advance!
Salvo
RE: Return: how get two more values and two lines? - Marcus von Cube - 03-08-2015 10:24 PM
(03-08-2015 10:12 PM)salvomic Wrote:  How to get two line in RETURN()?
The only way to return more than one value from a PPL program is to return a list or a vector.
RE: Return: how get two more values and two lines? - salvomic - 03-08-2015 10:35 PM
(03-08-2015 10:24 PM)Marcus von Cube Wrote:  The only way to return more than one value from a PPL program is to return a list or a vector.
understood...
I've more variable, and for now I do so:
RETURN ("ST ="+ st + " F = "+ f + " μ = " + mm + " σ2 = " + ss);
but there are already too things in a line...
And then, this is a string and I would like to get numerical values.
thanks
RE: Return: how get two more values and two lines? - Tim Wessman - 03-08-2015 10:48 PM
Export the variables by name you'd like the user to have access to directly. Store into those as the last part of your program.
RE: Return: how get two more values and two lines? - salvomic - 03-08-2015 10:51 PM
(03-08-2015 10:48 PM)Tim Wessman Wrote:  Export the variables by name you'd like the user to have access to directly. Store into those as the last part of your program.
ok, thanks, I'll try so.
