WP-31s on iOS - Printable Version
+--- Thread: WP-31s on iOS (/thread-3368.html)
WP-31s on iOS - pascal_meheut - 03-14-2015 06:54 AM
A WP-31s emulator is available on iOS (obviously based on the WP-34s one but they are 2 different Apps).
You can find it by searching for WP 31s in the "App Store" or here:
https://itunes.apple.com/us/app/wp-31s/id973621300?l=fr&ls=1&mt=8
Enjoy.
RE: WP-31s on iOS - Sanjeev Visvanatha - 03-14-2015 01:34 PM
This is great Pascal ! Thank you for your efforts. Installed on my iPad just now.
Technically, the 'About' page of the app should reflect the authorship of the WP 31S as per the users manual (pg 8). I believe it is missing Jonathan and myself.
RE: WP-31s on iOS - John Smitherman - 03-14-2015 03:01 PM
Well done Pascal. It installed flawlessly on my iPhone 5. The display is nice and clear.
Thank you,
RE: WP-31s on iOS - pascal_meheut - 03-14-2015 03:25 PM
(03-14-2015 01:34 PM)Sanjeev Visvanatha Wrote:  Technically, the 'About' page of the app should reflect the authorship of the WP 31S as per the users manual (pg 8). I believe it is missing Jonathan and myself.
Sorry about this. It will be fixed in the next release.
RE: WP-31s on iOS - Sanjeev Visvanatha - 03-14-2015 04:27 PM
Thank you!
RE: WP-31s on iOS - Michael de Estrada - 03-17-2015 01:07 AM
Fantastic ! Thank you so much.
RE: WP-31s on iOS - anetzer - 03-17-2015 06:21 AM
Amazingly fast booting time: On in an instant
Bravo and thank you!
RE: WP-31s on iOS - Sylvain Cote - 03-17-2015 11:09 AM
Installed on my iPhone 4S running IOS 8.2.
Great application!
Thank you!
Sylvain
RE: WP-31s on iOS - Marcus von Cube - 03-17-2015 11:56 AM
A few remarks:
On my iPad mini, the help text does not fit in its window. It is truncated on the right.
The register view is using two digit addresses. On the 31S a single digit suffices.
Other than that it is a very useful calculator app!
RE: WP-31s on iOS - Michael de Estrada - 03-17-2015 01:30 PM
(03-17-2015 11:56 AM)Marcus von Cube Wrote:  On my iPad mini, the help text does not fit in its window. It is truncated on the right.
Curious. I also have an iPad mini, and don't have this problem. I'm still running iOS 7, and the app version is 1.2.
RE: WP-31s on iOS - pascal_meheut - 03-17-2015 06:08 PM
Let me guess: this a non retina iPad Mini?
(03-17-2015 11:56 AM)Marcus von Cube Wrote:  The register view is using two digit addresses. On the 31S a single digit suffices.
I think the Qt version has the same problem: the code is the same as the WP34s. It should be easy to change.
RE: WP-31s on iOS - Marcus von Cube - 03-17-2015 09:09 PM
Your guess is 100% correct. The font scaling seems to be a bit different on this oldie.
RE: WP-31s on iOS - Michael de Estrada - 03-18-2015 12:10 AM
(03-17-2015 09:09 PM)Marcus von Cube Wrote:
(03-17-2015 06:08 PM)pascal_meheut Wrote:  Let me guess: this a non retina iPad Mini?
My iPad mini is non-retina as well, but it does not exhibit this problem.
RE: WP-31s on iOS - pascal_meheut - 03-18-2015 05:17 AM
It seems the difference comes from iOS version. They changed popups behavior so I'm working on it.
RE: WP-31s on iOS - Michael de Estrada - 03-18-2015 05:33 AM
(03-18-2015 05:17 AM)pascal_meheut Wrote:  It seems the difference comes from iOS version. They changed popups behavior so I'm working on it.
Just make sure it still works properly on iOS 7 when you're done. I don't want to update to iOS 8.
RE: WP-31s on iOS - pascal_meheut - 03-18-2015 07:13 AM
I will. The question is whether to support iOS 6 & 5 or not.
RE: WP-31s on iOS - pascal_meheut - 04-02-2015 12:09 AM
New versions of the WP-31s and WP-34s emulators should be available soon on the App Store and should fix the help formatting problem as well as the 31s credits.
