bug in command line with / ? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: bug in command line with / ? (/thread-3370.html) |
bug in command line with / ? - phgerin - 03-14-2015 08:24 AM Cas mode, textbook, last firmware. Lets say I have 'sin(x)' in the history. Now, I want to enter 2/sin(x), so I type 2 then / The cursor is on the denominator of the fraction. At this stage, if I select sin(x) in the history and press enter, sin(x) is inserted at a wrong place in the numerator (see screenshot). If I type 2 / then 'ans', everything is ok. Edit: bug only present when using the keyboard to select and not via the touchscreen. RE: bug in command line with / ? - Marcus von Cube - 03-14-2015 01:06 PM It's probably the first use of up arrow that moves the cursor inside the expression before the next 'up' enters the history screen. RE: bug in command line with / ? - phgerin - 03-14-2015 02:16 PM Correct, I didnt notice it. Thank you ! |
