Request: Toolbar commands - Printable Version
+--- Thread: Request: Toolbar commands (/thread-3418.html)
Request: Toolbar commands - compsystems - 03-18-2015 08:48 PM
Request: Toolbar
Hello, sorry for my bad English
For the team hpprime, is required a toolbar to create good programs with GUI
an example code of series ti68k calcs
[Image: AnimationOfPolyhedrons.png]
animTbar()
Prgm
  © animTbar(): Animations Toolbar
  Local chspolvl, chsplvl1
  Loop
    putbar({},0)
    Toolbar
      Title "Polyhedron"
        Item "Regular Polyhedron",regpollb
        © regular, convex polyhedron with congruent faces of regular polygons
        Item "Other important polyhedra",othrpolb
      Title "Paramts"
        Item "Set parameters page1/2",wparamlb
        Item "Parameters page2/2",wparm2lb
        Item "Parameters 3",wparm3lb
        Item "Default values",dftparlb
      Title "MakeImag",makeimlb
      Title "Animation",startalb
      Title "Delete Images"
        Item "All",delalllb
        Item "Current",delcrrlb
      Title "Quit"
        Item "Exit without del images",quit2lb
        Item "Delete All Images",quit1lb
        Item "Stop",haltlb
      Title "About",aboutlb
    EndTBar
    Cycle © to Loop
    Lbl regpollb:
    If polytype <= 2 Then
      polytype→chspolvl
    EndIf
    PopUp {"Tetrahedron. 4 Faces","Hexahedron (Cube). 6 Faces","Octahedron. 8 Faces","Dodecahedron 12 Faces", "Icosahedron. 20 Faces"},chspolvl
    If chspolvl = 1 Then
      0→chspolv
      Dialog
        Text "Tetrahedron is one kind of pyramid"
        Text "composed of 4 triangular faces."
      EndDlog
      poltype(1)
    Else
      If chspolvl = 2 Then
        0→chspolv
        Dialog
          Text "A cube is a hexahedron with all"
          Text "its faces square and three squares"
          Text "around each vertex."
        EndDlog
        poltype(2)
      Else
        If chspolvl >= 3 and chspolvl <= 5 Then
          0→chspolvl
          Dialog
            Text "Algorithms still not created,"
            Text "will be included in future releases."
          EndDlog
        EndIf
      EndIf
    EndIf
    Cycle © to Loop
    Lbl othrpolb
    If polytype >= 6 Then
      polytype-5→chspolvl
    EndIf
    PopUp {"Square Pyramid. 5 Faces","Triangular Prism. 6 Faces"},chspolvl
      0→chspolv
      Dialog
        Text "Square Pyramid is a pyramid, "
        Text "having a square base"
      EndDlog
      poltype(6)
    Else
        0→chspolv
        Dialog
          Text "1"
          Text "1"
        EndDlog
        poltype(7)
      EndIf
    EndIf
    Cycle © to Loop
    Lbl wparamlb:wparamts()
    Cycle © to Loop
    Lbl wparm2lb:wparamt2()
    wparm2lb
    Cycle © to Loop
    Lbl wparm3lb:wparamt3()
    wparm3lb
    Cycle © to Loop
    Lbl dftparlb:dftvalue()
    Cycle
    Lbl makeimlb:makepict(nimages,highpoly,dcrhigvl,hidedgvl,rotatnvl,axesflag,vert​exfl,polytype)
    Cycle © to Loop
    Lbl startalb:exeanimt(nimages,anidelay,maxcycle,rotatnvl)
    Cycle © to Loop
    Lbl delalllb:delpics(nimages,1)
    Cycle © to Loop
    Lbl delcrrlb:delpics(nimages,2)
    Cycle © to Loop
    Lbl aboutlb:aniintro()
    Cycle © to Loop
    Lbl quit1lb:exitprgm(nimages,1)
    Exit © to EndLoop
    Lbl quit2lb:exitprgm(nimages,0)
    Exit © to EndLoop
    Lbl haltlb:Stop
    Exit © to EndLoop
  EndLoop
EndPrgm
Survey is important to have a block of statements for this purpose?
+1
