MAKEMAT in RPN Mode - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: MAKEMAT in RPN Mode (/thread-3493.html) |
MAKEMAT in RPN Mode - toml_12953 - 03-27-2015 06:38 PM How do you store a matrix in a variable other than M1 - M9? The manual says it can be done but when I do this: 0 ENTER 5 ENTER MAKEMAT(2) 'A' ENTER STO I get an error. I also tried storing the matrix in M1 (which worked) then storing M1 in A which didn't work. Tom L RE: MAKEMAT in RPN Mode - Mark Hardman - 03-28-2015 12:57 AM Looks like a mistake in the manual. Variable 'A' is one of the built in Reals and cannot hold an object of a different type. Try creating user variable A1 and then following the steps in the manual substituting 'A1' for 'A'. RE: MAKEMAT in RPN Mode - toml_12953 - 03-28-2015 02:46 AM (03-28-2015 12:57 AM)Mark Hardman Wrote: Looks like a mistake in the manual. Yup, that did it. In a program, I can use A as a local variable and it works, too. This business of predefined variable types depending on what mode you're in is sometimes baffling for me. Thanks for the response! P.S. If that's not a signature, what is it? RE: MAKEMAT in RPN Mode - Mark Hardman - 03-28-2015 07:02 AM (03-28-2015 02:46 AM)toml_12953 Wrote: Yup, that did it. In a program, I can use A as a local variable and it works, too. This business of predefined variable types depending on what mode you're in is sometimes baffling for me. As others have pointed out, it is a carryover from the the HP-38G paradigm. A feature that is, supposedly, beneficial to educators as it simplifies use of variables. I can understand the benefit for special object types like matrices, lists and complex numbers. But why tie up the most valuable names by forcing them to be real? (03-28-2015 02:46 AM)toml_12953 Wrote: P.S. If that's not a signature, what is it? I know what it is not. It is definitely not a pipe! Code:
