Bolt Pattern - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP Prime Software Library (/forum-15.html) +--- Thread: Bolt Pattern (/thread-3508.html) |
Bolt Pattern - Eddie W. Shore - 03-30-2015 01:41 PM From my blog: http://edspi31415.blogspot.com/2015/03/hp-prime-ti-84-bolt-pattern.html The program BOLTPAT will calculate a bolt pattern given: X = center, X coordinate Y = center, Y coordinate N = number of bolts D = diameter of the circle No angle of rotation is assumed. Coordinates of each bolt can be calculated by: X_k = (d/2*COS(360*k/n)+xc) Y_k = (d/2*SIN(360*k/n)+yc) Where k = 0 to n-1 The OC-Distance between each bolt is calculated by calculating the linear distance between neighboring bolts. Output: Each point where the bolt should be placed. In addition, the on-center distance between bolts is displayed. Finally, each of the coordinates will be presented in a list. Code: EXPORT BOLTPAT() Example: Build a bolt pattern with 5 bolts of a circle of diameter of 3 units. The center of the circle has the center (1, 4). (X = 1, Y = 4, N = 5, D = 3) Bolts should be placed at the following points: (5.5, 1) (4.4635, 2.4266) (2.7865, 1.8817) (2.7865, 0.1183) (4.4635, -0.4266) OC-Distance: 1.7634 RE: Bolt Pattern - rgallier - 07-05-2015 01:41 AM This is my output with the given input: x + y*i (2.5,4) (1.46352549156,5.42658477444) (−0.21352549156,4.88167787844) (−0.21352549156,3.11832212156) (1.46352549156,2.57341522556) OC-OC: 1.76335575688 |
