mixing cas program with home programs: error - Printable Version
+--- Thread: mixing cas program with home programs: error (/thread-3526.html)
mixing cas program with home programs: error - leprechaun - 04-01-2015 06:01 AM
hi,
I read in Han's Explanation on cas programming that you can mix cas functions with ordinary programs. Or at least that it should be doable. I have a collection of useful programs in a source file named ownprg. atm there are only normal programs.
Now I decided to add a Little cas program, but even if I stick to the Skeleton I get a Syntax error.: like
EXPORT one_prg(a)
#cas
foo(args):=
#end
That gives the Syntax error. The line is #cas
. Any ideas of what I am doing wrong there???
RE: mixing cas program with home programs: error - Marcus von Cube - 04-01-2015 09:20 PM
(04-01-2015 06:01 AM)leprechaun Wrote:  That gives the Syntax error. The line is #cas.
Do you have installed the most recent firmware? #cas is a command that has only been added lately.
