Question... - Printable Version
+--- Thread: Question... (/thread-3550.html)
Question... - Spybot - 04-04-2015 03:24 AM
Hello every Body!
I have a question.
What causes a program to crash the calculator (x^2+y^2=1 screen) & the emulator... just by touching the screen while executing commands PRINT("text"); WAIT(-1); ?
Maybe this has already happened to someone before...
I'll appreciate any help.
Spybot.
RE: Question... - Tim Wessman - 04-04-2015 07:55 PM
I've not been able to reproduce this on either device or hardware. Could you provide a few more details with your exact steps? Everything I've tried has not resulted in any problem that I can see.
RE: Question... - Tim Wessman - 04-04-2015 09:40 PM
Ok, was able to see it. If you'd like to avoid the problem in the meantime then know that the only place you'd see this would be if running using the "RUN" button from the program catalog. Running SLK from the home screen or any other place won't have the issue.
Thanks for the code to demonstrate it.
RE: Question... - Spybot - 04-05-2015 03:30 AM
you're welcome Tim.
I'd like to share this piece of code, but for now I think I'll wait, so probably in future OS updates it won't show up anymore.
Spybot.
