Removing tag after units conversion - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Removing tag after units conversion (/thread-3567.html) |
Removing tag after units conversion - John Colvin - 04-06-2015 07:02 PM Does anyone know if there is a way to remove the units tag at the end of the number after converting from one unit to another. Example: 4.1244_in to 4.1244. I know I can simply pull the number from the stack and edit out the tag, but I was hoping there might be a quicker, more convenient way of doing this. RE: Removing tag after units conversion - DrD - 04-06-2015 07:49 PM You could just divide by one unit: 12_in/1_in ==> 12 RE: Removing tag after units conversion - John Colvin - 04-06-2015 10:21 PM (04-06-2015 07:49 PM)DrD Wrote: You could just divide by one unit: That works. Thanks. RE: Removing tag after units conversion - Joe Horn - 04-07-2015 02:14 AM (04-06-2015 07:49 PM)DrD Wrote: You could just divide by one unit: CAS.left(unit) is more cryptic but it also works, e.g. CAS.left(12_in) returns 12. One benefit of this method is that you don't need to know the unit; it strips off ANY unit or combination of units. RE: Removing tag after units conversion - John Colvin - 04-07-2015 09:10 PM (04-07-2015 02:14 AM)Joe Horn Wrote:Good solution Joe. I used the CAS method in my DTAG function for removing the units tag from the numerical result of a conversion on the 1st level stack.(04-06-2015 07:49 PM)DrD Wrote: You could just divide by one unit: |
