(40gs) & 39gs: PENTANACCI SEQUENCE INSTALLER (OEIS A124313) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: (40gs) & 39gs: PENTANACCI SEQUENCE INSTALLER (OEIS A124313) (/thread-3580.html) |
(40gs) & 39gs: PENTANACCI SEQUENCE INSTALLER (OEIS A124313) - Gerald H - 04-07-2015 04:04 PM Here a programme for the 40gs & 39gs only to install symbolics in the Sequence Aplet & produce the Pentanacci series in U1. Here more info on the Pentanacci series: http://oeis.org/A124313 PENTANACCISEQ MAKEMAT(I==1 OR I-1==J,5,5)►M1: [[1,0,0,0,0]]►M2: [0,0,0,1,0]►M3: RUN SEQSET: RECURSE(U,ABS((M2*(M1^(N-4)))*M3),1,0)►U1(N): CHECK 1: The programme SEQSET cleans the Sequence Aplet & sets flags as required. SEQSET SELECT Sequence: UNCHECK 0: 0►NumFont: 0►Simult: 2►Angle: 1►InvCross: 1►NumStep: 1►Format: 1►NumCol: 1►NumStart: 6►NumRow: RECURSE(U,0,0,0)►U1(N): Ans►U2(N): Ans►U3(N): Ans►U4(N): Ans►U5(N): Ans►U6(N): Ans►U7(N): Ans►U8(N): Ans►U9(N): Ans►U0(N): |
