Keyboard wish (proposal) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Keyboard wish (proposal) (/thread-3597.html) |
Keyboard wish (proposal) - Dirk.nl - 04-09-2015 07:39 PM Hello forum members. Two proposals (changes for HP), what do you think about this? Is it realistic? 1-) The yellow coloured keys (alpha) are very difficult to see, specially when there is not enough light. Sometimes I'm using the Chars key to type characters, select, echo, select, ... etc. On the char screen one row consist of 16 characters. So, two can consist 32 characters. I count 30 yellow keys. Is it possible for HP to create a touch keyboard with two rows like the iPad. On the underside of the screen. When you select "chars" followed by touching the spare black function key left from the OK (new name: Keyb) the touch keyboard appears on the screen. With ESC the touch keyboard will disappear. First row A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P Second row Q,R,S,T,U,V,W,X,Y,Z,#,:,=,",:=,; HOME; uppercase. Shift = lowercase CAS; lowercase. Shift = uppercase What do you think? 2-) Home screen, toolbox -> Math -> Arithmetic-> Percentage. After Percentage make a selection between %, % CHANGE and % TOTAL. Greetings, Dirk.nl |
