(50g) Bolt Pattern - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: (50g) Bolt Pattern (/thread-3599.html) |
(50g) Bolt Pattern - Eddie W. Shore - 04-10-2015 05:04 AM Bolt Pattern: BOLTPAT Link to the original blog entry: http://edspi31415.blogspot.com/2015/03/hp-prime-ti-84-bolt-pattern.html Input: 4: xc: x coordinate, center 3: yc: y coordinate, center 2: n: number of bolts 1: d: diameter of the circle Program: << DEG OVER 1 – → xc yc n d k << { } 0 k FOR I 360 I * n / DUP COS d 2 / * xc + SWAP SIN d 2 / * yc + (0,1) * + + NEXT DUPDUP 2 GET SWAP 1 GET – ABS >> >> Output: 2: list of bolts (x+yi) 1: OC-Distance |
