How can I calculate it with my HP...? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: How can I calculate it with my HP...? (/thread-3658.html) |
How can I calculate it with my HP...? - Csaba Tizedes - 04-16-2015 04:13 PM Can anybody give me a good advice how can I calculate the following probability example on my HP-20S? p= Cn,r(5,2) × Cn,r(85,3) ÷ Cn,r(90,5) The right result is for FIX 4 is 0.0225 Thanks! Csaba RE: How can I calculate it with my HP...? - PANAMATIK - 04-16-2015 05:03 PM (04-16-2015 04:13 PM)Csaba Tizedes Wrote: Can anybody give me a good advice how can I calculate the following probability example on my HP-20S? If you use registers it can easily be done with 5 INPUT 2 Cn,r STO 0 85 INPUT 3 Cn,r STO 1 90 INPUT 5 Cn,r STO 2 RCL 0 x RCL 1 / RCL 2 = Bernhard RE: How can I calculate it with my HP...? - Csaba Tizedes - 04-16-2015 07:38 PM (04-16-2015 05:03 PM)PANAMATIK Wrote: If you use registers... Thanks Bernhard - I figured out it also, but if I ask my question as "Can anybody give me a good advice how can I swim across the Atlantic Sea?" And you answer it as "If you use a boat it can easily be done", you can see that the "sailing" and "swimming" is not the same things... I tried it with some ways on my HP (for example with "forced" parentheses) and it is not works. I really like this little algebraic calc and I really like to use its functions, programming, statistics, and so on... but it's a sad thing to find a bug in the data entry routine. My calc is not here now, but I think I'll try all the functions which are use the INPUT key. Csaba RE: How can I calculate it with my HP...? - walter b - 04-16-2015 07:54 PM Thanks for your explanation - I first thought you were looking for a way to simplify the problem e.g. by cancelation of terms. d:-/ RE: How can I calculate it with my HP...? - PANAMATIK - 04-16-2015 08:56 PM (04-16-2015 07:38 PM)Csaba Tizedes Wrote:(04-16-2015 05:03 PM)PANAMATIK Wrote: If you use registers... Hi Csaba, Of course, I tried the parentheses too, and it didn't work. The parentheses were just ignored. It is well known that the HP-20S behaviour is not consistent. Ignoring parentheses in an algebraic calculator is a bug. Perhaps there is a little relict of RPN left inside. You have to take the sailing boat. Bernhard |
