time functions startTimer, checkTimer, tic, toc ... - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: time functions startTimer, checkTimer, tic, toc ... (/thread-3755.html) |
time functions startTimer, checkTimer, tic, toc ... - compsystems - 05-01-2015 02:20 AM Hello I have seen the power of response in hpprime =), I want to make some comparisons with other calcs and maths pc. I require timer commands for next firmware Thanks ti68K calcs Code: name_function(n) MatrixLab Code:
RE: time functions startTimer, checkTimer, tic, toc ... - Didier Lachieze - 05-01-2015 06:11 AM You can already use TEVAL(). RE: time functions startTimer, checkTimer, tic, toc ... - DrD - 05-01-2015 10:46 AM You could do a clock walk like tic toc, per your ti68k calcs and MatrixLab, ad hoc mock: Code:
RE: time functions startTimer, checkTimer, tic, toc ... - compsystems - 05-01-2015 08:26 PM The TICKS command, not is in the catalog. =[ TEVAL is difficult to know what it means. TimerEval or Similar 8 characters is to primitive calculators as ti68k RE: time functions startTimer, checkTimer, tic, toc ... - Thomas_Sch - 05-01-2015 08:37 PM (05-01-2015 08:26 PM)compsystems Wrote: The TICKS command, not is in the catalog. =[you could find TICKS in the the HELP system: Code: Syntax: RE: time functions startTimer, checkTimer, tic, toc ... - compsystems - 05-01-2015 09:05 PM I found TICKS after much searching ... in [HELP] [TREE] [MAIN] [ THE TOOLBOX MENU] [CATLG MENU] [P-T] TICKS [CATLG MENU] should be as shortcut to the tools menu buttom [TOOLS] menu [MATH] [APP] [CAS] [CATALOG] [all cmds and functions ] / [a-e] [f-j] ... [u-z] [OK] |
