Android emulator PDF help file issues - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Android emulator PDF help file issues (/thread-3803.html) |
Android emulator PDF help file issues - kharpster - 05-08-2015 01:26 AM I am having an interesting issue opening the Quick Start or User Manual from within the Android emulator. The associated PDF files are downloaded each and every time that I select them from the pullout menu in the emulator. They are renamed because they already exist so I end up with multiple PDF files. Also, the user manual is not downloaded in its entirety so it crashes when attempting to view it. I am running the emulator on a Nexus 7, and a Droid Ultra, the issue exists on both devices... Turning off the network connection confirms that the emulator is attempting to download the files each time they are selected. RE: Android emulator PDF help file issues - Tim Wessman - 05-08-2015 02:58 PM Rather strange. I know nobody has encountered (at least reported) this issue before and it is new to me. Could you please send an email to the support email for the application with a few details like your current language setting, what the files are getting named to and anything else you might think could be helpful? RE: Android emulator PDF help file issues - kharpster - 05-08-2015 06:58 PM Tim. If you provide me with the appropriate email address I will send the information necessary for the team to attempt to replicate the issue. RE: Android emulator PDF help file issues - Tim Wessman - 05-08-2015 08:05 PM calculators@hp.com is the email listed on the play store and will go directly there. |
