New Version Error Loading - Printable Version
+--- Thread: New Version Error Loading (/thread-3829.html)
New Version Error Loading - Helge Gabert - 05-13-2015 10:35 PM
OK, so I updated the virtual Prime, as well as the ConnKit without any problems.
However, updating the physical Prime doesn't work. I get "Error 20" messages, line after line, and the calculator is unresponsive and doesn't turn off.
How can this be so difficult? Windows 7 64-bit.
Thanks for any tips!
RE: New Version Error Loading - Helge Gabert - 05-13-2015 10:51 PM
Took the battery out, and I'm back to the old version. Luckily, it boots up.
But how do I upgrade?
RE: New Version Error Loading - Marcio - 05-13-2015 11:03 PM
Have you tried hard-resetting it with a paper clip?
After that, you could try again via connkit. Connect the calc to the connkit, go the 'help' menu and voila.
RE: New Version Error Loading - Helge Gabert - 05-13-2015 11:15 PM
Yes, I tried it a second time.
This time, I,m stuck at the V13 Upgrade screen. Again, calc doesn't turn off. Unbelievable.
RE: New Version Error Loading - Helge Gabert - 05-14-2015 12:17 AM
Finally, it worked!!! After forcing re-detection of the USB driver, see Tim's note under (B) in his thread. Thanks!
