SLK 3.1 (Straight Line Kit) for the HP Prime. "Updated-Nov-2015" - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: SLK 3.1 (Straight Line Kit) for the HP Prime. "Updated-Nov-2015" (/thread-3842.html) |
SLK 3.1 (Straight Line Kit) for the HP Prime. "Updated-Nov-2015" - Spybot - 05-14-2015 11:54 PM Hello! Today I just updated SLK 3.0 to 3.1 you can download it here ENJOY... SLK has been tested on FW 6975, 7820 and 8151. I hope you guys like it and find it useful (specially Students). SLK 3.1 (Straight Line Kit "Updated") it is specially focused on the straight line, helping the User to find: 1. Distance between two Points. 2. Slope between two Points. 3. The equation between two points. 4. Distance between Point & Line. 5. Collinearity of 3 Points (MidPoint/EndPoint). 6. Point-Slope Equation. 7. Transforms Ax+By+C=0 to y=mx+b and vice versa. 8. Finds the coordinate representation of a straight line. 9. Determines whether or not two straight lines are parallel or Perpendicular. 10. Finds the (x) & (y) Intercepts of a straight line. 11. Finds the intersection point between two straight lines. 12. Transform a non-standard form equation of a line into a standardized form of it. Best, RE: SLK 3.0 (Straight Line Kit) for the HP Prime tested on: (OS Rev 7820) - cyrille de brébisson - 05-15-2015 01:16 PM Hello, Cool, thanks for contributing! Nice program. Cyrille RE: SLK 3.0 (Straight Line Kit) for the HP Prime tested on: (OS Rev 7820) - salvomic - 05-15-2015 01:18 PM (05-14-2015 11:54 PM)Spybot Wrote: Hi Everyone! hi Dante! thanks a lot to have cited also me in your nice program, that's very interesting and useful. Very compliments, it's linear, neat, beautiful. Also PDF is well done! Salvo RE: SLK 3.0 (Straight Line Kit) for the HP Prime tested on: (FW Rev 7820) - compsystems - 05-15-2015 06:00 PM Buena biblioteca, si deseas puedes agregar lo siguiente Code:
RE: SLK 3.0 (Straight Line Kit) for the HP Prime tested on: (FW Rev 7820) - akmon - 05-15-2015 06:29 PM Thank you for your useful program. I recommend you to post on the HP Prime software directory, in this web. RE: SLK 3.0 (Straight Line Kit) for the HP Prime tested on: (FW Rev 7820) - Spybot - 05-15-2015 06:44 PM Thanks Akmon I will. RE: SLK 3.0 (Straight Line Kit) for the HP Prime tested on: (FW Rev 7820) - Aries - 05-16-2015 11:40 AM Hey Spybot, thanks for your great work, I much appreciated it ! Could you add the condition of collinearity of three points ? And what about conic sections (circumference, parabola, ellipse) ? Are you going to implement those in the future ? Best, Aries RE: SLK 3.0 (Straight Line Kit) for the HP Prime tested on: (FW Rev 7820) - salvomic - 05-16-2015 12:36 PM Dante, can you also put here the code of the program (or a zip)? :-) thank you again! Salvo RE: SLK 3.0 (Straight Line Kit) for the HP Prime tested on: (FW Rev 7820) - Spybot - 05-16-2015 04:13 PM LOL. Thank you Salvomic something happened while I was uploading the file, it is available now. RE: SLK 3.0 (Straight Line Kit) for the HP Prime tested on: (FW Rev 7820) - salvomic - 05-16-2015 04:14 PM (05-16-2015 04:13 PM)Spybot Wrote: LOL. :-) thank you, I downloaded it yesterday, here... have a nice day RE: SLK 3.0 (Straight Line Kit) for the HP Prime tested on: (FW Rev 7820) - Spybot - 05-16-2015 04:37 PM Hi Aries. I think the sixth option from the main menu (MidPoint/EndPoint) will do the trick for: "collinearity of three points", I just labeled it with a different name. Regarding to conic sections: (circumference, parabola and ellipse) It's a great Idea, in fact I've already thought about implementing something like that, it's just that time happens to be my main limitation. perhaps it could be possible in a near future. |
