Choose Funktion in an Choose Funktion - Printable Version
+--- Thread: Choose Funktion in an Choose Funktion (/thread-3875.html)
Choose Funktion in an Choose Funktion - Heino - 05-17-2015 02:08 PM
Hello all,
How can i create an choose function i a choose function?
RE: Choose Funktion in an Choose Funktion - Spybot - 05-17-2015 04:00 PM
Hello Heino!
Did you mean something like this?
EXPORT Prog()
LOCAL VARIABLE_01,VARIABLE_02;
CHOOSE(VARIABLE_01,"TITLE",{"OPTION_01","OPTION_02","OPTION_03"});
CASE
IF VARIABLE_01==1 THEN MSGBOX("COMANDS_01") END;
IF VARIABLE_01==2 THEN MSGBOX("COMANDS_02") END;
IF VARIABLE_01==3 THEN CHOOSE(VARIABLE_02,"TITLE",{"OPTION_04","OPTION_05","OPTION_06"});
CASE
IF VARIABLE_02==1 THEN MSGBOX("COMANDS_04") END;
IF VARIABLE_02==2 THEN MSGBOX("COMANDS_05") END;
IF VARIABLE_02==3 THEN MSGBOX("COMANDS_06") END;
DEFAULT
DEFAULT
RE: Choose Funktion in an Choose Funktion - Heino - 05-17-2015 05:59 PM
Hello Spybot,
thanks for your answer. That´s a good solution, but I search for another one.
See Screen1.
RE: Choose Funktion in an Choose Funktion - petaks01 - 05-17-2015 07:10 PM
Where did you get the screenshot from?
I guess the code behind it has some hints...
RE: Choose Funktion in an Choose Funktion - kharpster - 05-17-2015 07:26 PM
(05-17-2015 07:10 PM)petaks01 Wrote:  Where did you get the screenshot from?
That looks like a system menu/sub menu and not a choose command. In so far I can tell we do not yet have the ability to create submenus in our programs.
RE: Choose Funktion in an Choose Funktion - Heino - 05-17-2015 07:47 PM
Okay, you are right. But I have made my solution with Spybot's program.
Thank's all.
Heino
RE: Choose Funktion in an Choose Funktion - John Colvin - 05-17-2015 07:54 PM
Sub menus can be created, but not in the cascaded style in the screenshot. I created a custom choose box popup menu with sub menus where the sub menu replaces the parent menu on the screen. I use it to consolidate some of my most used programs.
That isn't the cascaded style but probably the next best thing.
lastunit:={0,0};
KEY K_Space()
local list1:={"Electrical Eng",
"Geometry","Deg2Rad",
"Rad2Deg",
"atan2","DTAG",
"Slope"};
local list2:={{"Parallel_Resistance",
"Coulomb","in"},
{"Area_circle",
"Vol_sphere",
"Area_cyl"}};
local c1,c2;
if lastunit(1) OR lastunit(2) then
c1:=lastunit(1); c2:=lastunit(2);
choose(c2,list1(c1),list2(c1));
else
c1:=0; c2:=0;
end;
if c2==0 then
repeat
choose(c1,"User Functions",list1);
if c1<3 then
else
RETURN list1(c1);
end;
until c1==0 OR c2;
lastunit:={c1,c2};
end;
if c2 then
return(list2(c1,c2));
end;
This program is based on example that I believe Han posted a while back to a similar question that I had about nested popup menus.
