Error report:: a little guide line - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: Articles Forum (/forum-14.html) +--- Thread: Error report:: a little guide line (/thread-392.html) |
Error report:: a little guide line - patrice - 01-10-2014 10:46 PM This little guide have Prime in mind, but the advices can be applied to other systems. When you report an error, the first thing to do is to make sure the error is not on your side. Make sure that the parameters that are fed to the buggy function are really what you think they are. Make them appear clearly in your code. the process to set the parameters doesn't matter. Albert Einstein advice: “Everything should be made as simple as possible, but no simpler.” Aka when you provide code, don't make it 20 lines when 4 lines is enough to exhibit the problem. Bigger examples can be Ok for problems like memory leaks - Give a context: Calc or Emulator, Revision - Settings if needed - a description of the error or bug, keep in mind that the readers don't know what you speak about. Be as clear as possible. - a procedure to reproduce the problem (as short as possible) Example 1 This piece of code is claiming a compiler error in EXPR function Code: EXPORT SYMBOL1,WHATTYPE; -the input is part of what is fed to EXPR -the code don't show the string fed to EXPR as it is build on fly in EXPR This is a reduced piece of code Code: EXPORT Indirect_Addressing() Example 2 a bug by design with logical values, False is 0 and true is non zero. AND, OR and NOT operators are documented as logical operators, thus handling only True and False values. and we have bitwise functions BITAND, BITOR, BITNOT and BITXOR to handle all binary bitwise operations. it turn out that if you give binary integer values to logical operators, they silently turn to bitwise; the problem: it is undocumented. it is also unneeded since the bitwise functions are doing the job. to circumvent the problem, one have to compare with zero before using logical operators. (#12 <> 0) AND (#2 <> 0) |
